#171 |
Are you shure that is a geometry issue with the pivot ball?
I would guess the same as Trevor... |
#172 |
Liked 293 Times in 65 Posts
Yes, when the pedal is all the way up, the fork hits the hat so the bearing can't come all the way back. Then the clutch slips and overheats.
#173 |
Liked 115 Times in 35 Posts
Had this same problem with my quick time bell. I removed the locknut under the adjustable pivot ball so as to move the ball back more. This allows the clip on the fork to fit on the ball. Than welded the ball to the threaded collar. Hope that makes sense!
Also what wheels are on your car? Seen them just did not know who makes them. |
#174 |
Paul, it sounds like you did not have enough freeplay between the throwout bearing and levers. It gets worse when the clutch wears because the levers come up higher. Of course they come up as the rpm comes up. It acts like you are riding the clutch.
The QTs are approx. .200 more shallow then the lakewoods. It is important to use an adjustable pivot ball and the correct throwout bearing and fork. There is a blocksaver you can getmthat is thicker than the one that comes with the QT that can help also. E mail or call me. Jim
James Schaechter 3163 STK |
#175 |
Liked 520 Times in 132 Posts
That's why I sent my QT to browell and he set it up with the solid fork and Heim joint. You do have to trim the fork to fit with a McLeod clutch.
#176 | |
#177 | |
You have the same fork and throwout bearing, but not the same clutch and maybe not the same block saver. That can make a difference. We use the thicker block saver. Also, if you have a pressure plate that has washers under it and a thicker disc, that can take away more clearance as well. Finger height is a big deal too. We have been trying a different clutch and had to trim up our fork and change the linkage on our clutch pedal to make it work. Pretty tight in there! ![]() Just some stuff to check.
#178 |
James,
Please call me @ 692-418-9797 Thanks
Jeff Lee 7494 D/S '70 AMX |
#179 |
Liked 2 Times in 2 Posts
X2 Paul you have a beautiful car and it sure looks good on TV.
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
#180 |
Jeff, I tried that number and it did not go through. Jim.
