Old 09-16-2007, 09:42 PM   #1
Joe Pinkston
Joe Pinkston's Avatar
Default Re: Alternator Wiring
I assume you have a master cut off switch on the back of the car (but I know what can happen when you "assume"). If you do have a cut off switch then the wire needs to run to the battery side of the cut off switch in order for the switch to do the job it was designed to do.
Joe Pinkston
2155 S/ST
Joe Pinkston 2155 S/ST
Joe Pinkston is offline   Reply With Quote
