#21 |
Liked 184 Times in 113 Posts
Are we allowed to use a 4 Speed (4L60) auto if we use only the 1-2-3 Gears?
D |
#22 | |
Liked 226 Times in 76 Posts
Being a newby I would say that I am surprised you are allowed to triangulate the stock suspension mounts with DOM tubing. Then again the rule book doesn't say you can't. If and when we put the 396 in our 69 Chevelle to go C/S racing I am going to do the same. Have you talked to your Division Tech about where the triangulation 'stops' being legal? Good looking build.
Andy Friar |
#23 |
VERY NICE! I love big cars with 4-speeds! The way it was! What motor combo will be run? I'm not too familiar with stock elim. stuff, I guess its a 396-350hp oval port base? I think I have a good steel crank if needed. -Mark
#24 | |
#25 |
Liked 53 Times in 16 Posts
Here is the completed rear- 4:88's Moser 33 pline spool with rifle drilled axles, "star" flanges, also rear upper control arms, $30 each to builld in parts, not a "dime rocket" but the last time i had someone else fabricate them for my 68 they were $400- don't have that $ now! Also my "poor boy" solid front upper control arm brass bushings. Chucked up on a lathe years ago machined to fit my control arms. Donated brass- total cost $0 Car is wrapped up outside from snow, frame is attached now.
Will Lamprecht 65 Impala 396/325 I/SA in progress |
#26 | |
Liked 33 Times in 16 Posts
TRANSMISSION, Automatic Any model transmission, same make as car, with a maximum of three forward speeds (unless OEM equipped with more than three forward speeds). O.D. gear not required, reverse permitted.
Rich Taylor I/SA - 321 |
#27 |
Liked 7,886 Times in 1,753 Posts
Looking good Will, I can't wait to see it at the track!
#28 |
Liked 800 Times in 237 Posts
Nice work! -Al
"That'll never work....." |
#29 |
Liked 46 Times in 29 Posts
looks great. weather stinks here in ny. pics are good these days, lol.
#30 |
Is that a brace in that location? If so, how dose the panhard bar attach,and work? I had to modify one just to clear that type of cover.Thanks.
