Old 01-07-2014, 08:11 PM   #1
MICROMACHINE72
Default Re: Hi all! New Guy here, Low Buck Comp build, E/ED
Originally Posted by Glenn Hayes View Post
I all for you, so good to see someone doing it the way it used to be done.
Have you ported your cylinder head yet?
Thanks! I just started on the cylinder Head, I actually have 3-cores. I will do one the best I can myself, then when I get a few extra bucks this spring I'm going to send another out to Sissel or Valley Cyl. head for a pro-port job and compare results. Finally finished the TQ plate, got the carb adapters on the intake. Going tomorrow to use a buddy's flow bench for some pre-lim data. Also picked up 2-donated holley 500 cfm 2-bbls. Going to try them on the dyno first, along with 2-450 mech. sec. 4-bbls- than finally the 2-660 center squirts. Project moving a little slow at the moment, but nevertheless is moving..
ID:	22595   Click image for larger version
MICROMACHINE72 is offline   Reply With Quote
Old 03-26-2014, 03:58 PM   #2
Todd Hoven
Guest
Posts: n/a
Any more progress or updates?
Old 06-04-2014, 09:30 AM   #3
Bill Baer
What's Up with MICROMACHINE72? Did he pass away ? Get Divorced! Or maybe he just went fishin???
Old 06-08-2014, 09:33 PM   #4
Steve Williams
I saw an ad and it appeared that he has everything for sale.
Steve Williams is offline   Reply With Quote
Old 07-15-2014, 08:51 PM   #5
MICROMACHINE72
Still kickin' over here. Yes, sort of gave up on the 6 project, first motor did not make the HP I was hopeful for. Played with it a little longer, and as money and time was wearing thin I ended up putting a sbc back in the car for now.. Yes, I had advertised some stuff for sale, nobody with any real interest even just about giving it all away, I'll just sit on the stuff for now.
Old 07-17-2014, 02:27 PM   #6
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Where did the motor tap out? Where do you think the combo was lacking most? Also, how much power were you looking for? I've been told that the majority of power is in the heads and valvetrain. Anyway, just curious of the final results, really sorry your build didn't go as expected. Just like you, I want to build essentially a junkyard motor and build around most of the OEM parts but it will be a while before I get to that point.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 07-19-2014, 08:38 PM   #7
MICROMACHINE72
Definitely heads and intake. first motor with a very flat power curve gave up at 367 hp.. only 6500-rpm. I needed at least another 100-125hp to make it even fee sable. The 5.4 mod con rods could not take the heavy TRW slugs either. even with max lightening, piston-pin. Motor needs custom pistons, big dome, big$$$ and alumn. rods, no doubt, I new that going in.. I think the flat tappet cams would have worked, but needed a much better head than my home ported 240 stocker. I may revist this some day, but I was itching to go racing, and a $1500 355 sbc with Killer Rons toilet on alky makes 550+hp. too easy and cheap to go much faster for now!
