Old 02-18-2014, 06:04 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 551 Times in 215 Posts
Default Re: How does a Throttle Stop know it's a burnout
A Dedenbaer electric plate stop needs to be powered to be wide open.
In the old days when we used those stops with no timer.....I had a toggle switch to power it on the burnout....so it would be wide open.....that circuit just over rode the other normal circuit....
after that it was powered thru a switch on the shifter....wide open in low gear only....
If you are taking power away during the burnout the blades will close....
Rich Biebel
S/C 1479
Stock 147R
