Liked 364 Times in 138 Posts
I think quadrajetparts.com has a 2 piece solution for you. A 1" extension plus an inverted flare to -8 adapter.
Dave Turner SS/GT #1153 |
#2 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
#3 | |
http://quadrajetparts.com/rochester-...ing-p-436.html Then you need this adapter - (available from other sources.) http://quadrajetparts.com/rochester-...ing-p-370.html I assumed that you were working with a Quadrajet carb. The search continues. ![]()
#4 | |
Liked 544 Times in 213 Posts
I raced a G/SA Nova back in the mid '90s for a season or two.
P/G 350/255 It went high 11's with a very old school engine. It did sixty foot very well for the et......low 1.50's so If I had that Camaro with a 3 speed and hi compression engine I would be looking for 60 foot times in the low 1.40's.... The hi compression engines were always tougher to make run fast relative to the low compression engines. HP difference was not realistic. I still would like to have that car.....I like my dragster but still love Camaro stockers....Have fun...enjoy it...
Liked 507 Times in 116 Posts
This is what I use in mine with my Edelbrock Q-Jet
![]() http://www.jegs.com/i/Russell/799/640350/10002/-1 You can use a 45 degree AN fitting on your hose or use one of these if you already have a straight fitting. ![]() http://summitracing.com/dom/parts/ea...8erl/overview/
68 Chevy11 327 F/S |
#7 | |
E/SA and a good car is probably running 10.80 in decent air.
11.20 is a good start and MPH tells the tale on power. 115-116 is probably also a realistic number to expect. They tend to MPH pretty weak..... Whatever it runs......do a little tricky math I do to gauge how it is running. Multiply your ET by your MPH and see what number comes up. 1300 is weak on MPH and most stockers would run numbers in the 1300's or 1310's Fast cars that run good MPH will be 1340 or higher A very good balanced bracket car is in the 1330's.... It's just a factor number that can help gauge how well a car ET's vs MPH...and since Stockers ET very well vs MPH they will be at the low end of the scale... Steep first gear.....low gear in the rear.....good for ET's .... Restrictive cam,heads and intake manifold.....not good for MPH... Fast bracket cars like my dragster will pick up 30+ mph on the back half......I run an average of 146 at the 1/8th and run 177-178+ with injection...... Stockers are fun but slow by comparison.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 03-04-2014 at 12:29 PM. |
