Liked 544 Times in 213 Posts
A bad converter would not act like the tires spun....it would act more like you left in second gear...They tend to lose stall speed and get tight and make a car leave very lazy.....
That Dexron VI fluid should not be an issue When I had a Metric trans I did burnouts starting in 2nd and quickly shifted to 3rd...but that should not really be a cause for a problem. Sounds like the trans may have lost first gear....or fluid level is low... Does the ATF fluid look clean and the same color as it was....? Any slippage in a trans quickly turns the fluid dark and may smell burnt...
#2 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
