Liked 147 Times in 54 Posts
first and foremost great to see young blood
interest in stock. you have tapped the right source for info. i will leave the advice to the many experts. 48 years old and tired from a long days work...
Randy Hyman. Lakewood co. stk 5394 P/SA |
Liked 33 Times in 16 Posts
Congrats and enjoy yourself first and foremost. That will be an expensive Stocker when all is said and done. For right now I would would just bracket race it as is with minimal changes. I ran a "99 Z-28 in NMCA EFI back in 1999 and it was a beast with and without nitrous. Expect high 12's on the motor alone with good air. You can run an inexpensive ratchet locker in that 10-bolt, a shift kit in the trans, M/T drag radials, a tuner, stock convertor and 4:10 gear with good results. Install a tach and shift at 5000rpm...you will lose et shifting higher. Save your coins for the Stocker pieces that will be needed later like a 12-bolt housing, decent trans, efi components...you will be digging deep when it comes to the motor. If you are serious I can send you a tach bracket which does not require any holes to be drilled into the dash. I can also tell you how to safely shift the transmission using the factory console shifter.
![]() Btw, this car ran a 11.66 at Rockingham in '99 and backed it up again at Red River in Shreveport the following month using the same parts mentioned above plus a 100 shot dry nitrous system. Winner at Shreveport and Bowling Green that year and multiple runner-up's.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-14-2014 at 11:39 PM. |
Thanks for the help. The first thing I will get is 4.56 gears
Liked 18 Times in 9 Posts
Rich, you have a pm
