Any recommendations?
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 333 Times in 180 Posts
what are you trying to accomplish and is cost a consideration----FED387
Looking to replace battery in stocker, cost is a consideration, however we all know that cheaper can cost more in the long run
next ? how light is light?? personally I would look at a Braille or ,Deka (you can get DEKA at NAPA) or a Shorai which is a carbon fiber lithium ion battery both of these are 12 volt but you can get 16 volt too ---better get your wallet out if you go with carbon fiber or 16 volt they get pricey real quick
Liked 33 Times in 16 Posts
Just updated our Stocker with a Braille B3121 - 755 cranking amps and 21 lbs. We probably could have gone with the 18lb battery, but I'm a worry wart.
Rich Taylor I/SA - 321 |
Liked 93 Times in 52 Posts
This Odyssey battery turns my 13:1 383 with solid roller valve springs.
It has 900 amps for 5 seconds. http://shop.odysseybattery.com/p/pc925-a http://www.jegs.com/i/Odyssey-Batter...PC925/10002/-1 Not sure why Jegs is so expensive. It is available at several places. $147 -- http://www.amazon.com/Odyssey-PC925-.../dp/B0002ILK72 You will need to use metric bolts for the lugs or purchase the additional posts for post style. |
#7 | |
Liked 275 Times in 76 Posts
Sean
Liked 28 Times in 15 Posts
Deka powersports batteries are AGM and half the cost of the Brand Names (Braile, etc) I have used the 18 lb and will replace it with the 21 lb this year. With FI and FI fuel pump, elect fan and WP, FI computer, etc the 18 lb is marginal if going rounds without time for charging. You can search Google or Amazon for the Deka batterys. (They may be the maker of the NAME batterys specs and weights seem the same))
Thanks all, I'll look into the Braille and Deka batteries
Hey Bill I've been running the PC925MJT - Odyssey*battery for 6 years and no problems but thinking of switching to the Braille B14115C. It's pretty much the same cranking stats but half the weight. Only 11.5lbs compared to Odyssey 26lbs. Of course it's 100 bucks more
Don Fardie 1582 F/S B/G |
