Liked 531 Times in 108 Posts
Personally, I would ditch the steel motor mounts and replace them with stock units. I believe either all steel, or all rubber mounts. Then, install a torque strap on the left front of the engine.
Jim Kaekel 3836 STK |
Liked 799 Times in 236 Posts
Another culprit can be the bellhousing dowel pins, if they've been changed. Some of the after market extra length pins are a bit bigger i.d. than the factory ones, causing the case to be stressed when bolted to the block. -Al
"That'll never work....." |
Liked 1,032 Times in 368 Posts
Rossler has told me many times, that too much pinion angle breaks transmissions more than anything. He must see a lot of that.....
Jeff Niceswanger 3740 SS |
#4 | |
Liked 2 Times in 2 Posts
This is my sons car, I ran a full body 69 Chevelle with a big block and turbo 400. The car went 12:00-12:30 with stock suspension. The car would twist and pull both wheels,and I never broke a tranny in all the years I ran it. It had solid mounts up front and rubber at the trans. This car should not have an issue going mid to high 13's. Talked to the old owner of this car and he had the same problem. We put the tranny in 3 years ago. We need to keep looking. |
Liked 319 Times in 68 Posts
Broke 4 TH-200's in my son's 85 Camaro, had solid motor mounts and rubber trans mount. Tried different driveshafts ,solid trans mount,new renforced crossmember,different transmission, brace on case etc. Finally put all stock mounts on engine and trans and never broke another case in 7 years.
Lee Valentine 1661 STK |
Liked 684 Times in 289 Posts
I broke the bell in my 12 second bracket car, 355/ TH-350 Camaro.
It had factory urethane mounts on the front crossmember and steel mounts bolted to the block, like they came in 1979 The driver side motor mount was slightly bent and the engine was cocked up on the drivers side, just a bit. Could hardly tell, if you weren`t looking for it. Found the bent mount when I pulled the motor. Had rubber trans mount as well Check the motor mounts are the same and not bent. Just a thought... Good luck. |
Liked 1,826 Times in 414 Posts
If this car has the stock suspension, un-altered, other than urethane bushings, and the rear end housing has not been changed, damaged, or otherwise altered, if the frame is not bent or broken, then the pinion angle should be close to stock. Unless the ride height is significantly altered from stock.
Now, if it has traction bars, no hop bars, adjustable control arms, the housing has been swapped or altered, or the ride height has changed significantly, then the pinion angle could be off. If the pinion angle was off enough to break something, there should be a vibration present. Of course, solid motor mounts bring about a vibration of their own, and that could mask any vibration brought about by another cause. <------- Another reason that I despise solid motor mounts. If the dowel pins do not protrude into the case far enough that the chamfer on the pins is well past the chamfer on the case, so that the full diameter of the dowel pins is well into the holes in the case, that could cause the problem. At static ride height, the slip yoke should be about 1" out from being fully bottomed in the extension housing. I think the first thing I'd do is verify that there are no problems with the rear suspension or rear end housing, and that the driveshaft is correct, in length and in tubing diameter and thickness, as well as having good u-joints. After that, I'd put the mounts back to the stock configuration, either new high quality rubber mounts, or new urethane mounts, on the engine and transmission. If you want, you can fabricate a torque limiter of some sort. I'm betting at that point your case breakage problems will cease.
Alan Roehrich 212A G/S |
Liked 574 Times in 212 Posts
All of these suggestions sound logical to me.....let me just throw something else out there, in case these suggestions don't fix the problem. I have seen where the back of the blocks were crooked, therefore requiring shims to be sure the bell housing aligns "straight"..
"back in the day", it was common to break 4 speed transmission housings......after dial indicator and shims, I never broke another. Good Luck
Gary Hansen - SS/FA 4911, B/SA 4911 |
Thanks for all the ideas.
I like the idea of going back to the factory front mounts,considering the power level we are talking. |
Liked 269 Times in 99 Posts
Great thread!
The reasoning for not using solid engine mounts to avoid this problem may be a good bandaid for the real problem: Chassis Flex. When building my cars spent a lot of time making the floor pan stiff welding all seams top and bottom with the car level then locating roll bar mounts with chassis stiffness the intent within the rules. A lot of hard dirty work but makes stock chassis cars stiff and lets the suspension work. Rubber body mounts on A and G bodies replaced with solid steel or aluminum helps a lot. Even though this is a 13 second car doesn't mean there is no flex. Get rid of it and pick up some ET. Good Luck!
