About the solid side motor mounts:
If you run a production block (Bow Tie blocks didn't exist when I was showed this.) Bare block, with something soft below the test cylinder, put an inside mic in the cylinder above the soft pad, front-to-rear, up top, barely tight enough to stay in place. A healthy guy with hand above & below the mic, press hard & fast together and watch the mic fall to the pad. The old guy-machinist that showed me this about 50 years ago was no body builder either. Think about your ring seal during launch in the cylinders next to those solid motor mounts. I would use a torque strap with stock mounts myself.
Ed Wright 4156 SS/JA |
Liked 285 Times in 87 Posts
jbt352… Mount the body solid to chassis by welding flat bar between frame and body mount reinforcement pads (helps reduce chassis flex). Check to see if your rear upper and lower control arm bushings are in good shape, worn bushings can change pinion angle on acceleration. I'd add a aluminum convertor cover off a mid 80's GM 4x4 to act as a case girdle in the bell housing area. You have lots of positive feedback from your post. Good Luck…Maurice.
#3 | |
Liked 251 Times in 125 Posts
