Old 03-29-2014, 07:35 PM   #1
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: Breaking bell housings
About the solid side motor mounts:
If you run a production block (Bow Tie blocks didn't exist when I was showed this.)
Bare block, with something soft below the test cylinder, put an inside mic in the cylinder above the soft pad, front-to-rear, up top, barely tight enough to stay in place. A healthy guy with hand above & below the mic, press hard & fast together and watch the mic fall to the pad. The old guy-machinist that showed me this about 50 years ago was no body builder either.
Think about your ring seal during launch in the cylinders next to those solid motor mounts. I would use a torque strap with stock mounts myself.
I remember reading years ago that Bob Glidden built engines on the floor so that the cylinder walls would'nt distort. That made me think some, and that usually hurts!
