Old 04-01-2014, 08:44 AM   #1
Keith 944
Keith 944's Avatar
Default Re: BBC dome fitting
check the sides of the domes for barely hitting the head. had this happen on some closed chamber heads....as you prob. know, use clay and check without head gasket. too much clearance is better than not enough, lol
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-01-2014, 09:01 AM   #2
richie 2
Liked 205 Times in 93 Posts
10 o'clock area looking into the exh. port is the major interference spot. ill play/doe the sparkplug to get that clearance. usual .005'' deck and .041'' gasket. im laying back both the dome and & chamber a touch at a time. I agree, better enough room than too close...just call me the human milling machine.
Old 04-02-2014, 09:48 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Put the head on the empty block and scribe the head in the area of the ex. Lay the head back to the cylinder wall and then scoop the quench area out on that side to direct the flow toward the ex port/valve. The spark plug tip needs to be at least .100 away from the piston when it is positioned @ approx 36-40 degrees before TDC. .035-.040 @ TDC. I've done this on a couple of SS engines as well as shifted the heads with offset dowels (intake toward the center of the cylinder) and seen over .010 in ET & some MPH improvement .
Adger Smith (Former SS)
Old 04-03-2014, 10:58 AM   #4
richie 2
lots of room everywhere else after testing. going to file a slight angle of the chambers edge at the exh. valve/dome area to be sure theres enough room at its radius. that will give us more room there being the closest and hard to measure.
Old 04-03-2014, 01:00 PM   #5
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Are you working with a 4.250 or larger bore ? I have done a couple 454 based motrs w/049 heads and big old Speed Pro open chamber pistons with good results.
Old 04-03-2014, 01:56 PM   #6
richie 2
tks everyone. tim yes it's a 4.310'' bore x 454ci stroke w/781 head. so you had relieving to do?
Old 04-03-2014, 08:16 PM   #7
Tim H
Tim H's Avatar
Yup, in the exh valve area, I had switched to 1.88 " valves as well. A bit off dome and a bit of chamfering on chamber as I recall.
