Old 04-13-2014, 09:06 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Yeah, I'm going to send it off for repair and keep it as a spare. I will order a new one Monday...may have something in the shop to stick in there for the upcoming Combo race this Saturday.
Rich Taylor
I/SA - 321
Old 04-13-2014, 04:32 PM   #2
HandOverFist
Looks like my initial diagnosis was not complete. When I pulled the convertor out I found this...stator support shaft the correct terminology???
By the appearance of the shear site it looks to have already been broken...there are three shiney spots which is probably all that was holding it together. I'll attribute this back to the prior driveshaft/housing perch failure fiasco. I told you it was rather violent lol!
Anyway, with this set-up out of commission for a spell I slipped the PG back in temporarily. I'll try to hook up with Thomas at Bowling Green and pass off the trans and convertor to him for repair. Convertor status is unknown and I think it would be prudent to let ATI cut it open for a look-see.
On a positive note the added fuel gauges showed me that the fuel system is working well...was still showing 6-1/2psi thru the lights.
While the car may not be as peppy with the PG, I'll still be at the Beech Bend Combo race this Saturday...what else could go wrong?
Rich Taylor
I/SA - 321
Old 04-13-2014, 05:16 PM   #3
brent flynn
brent flynn's Avatar
Dang man! You are hard on stuff! hehe... atleast you found the problem...
Gimme some info on the guage line and guage that you installed... i need to do that as well...
Old 04-13-2014, 06:18 PM   #4
HandOverFist
Pm sent Brent -
Rich Taylor
I/SA - 321
Old 04-18-2014, 07:27 PM   #5
HandOverFist
Beech Bend Combo bound in the morning. This will be my first race with this car and the first S/SS race I have ever entered. I'm sure it will be a learning experience. I'll try to get some pictures to post up after the race.
Rich Taylor
I/SA - 321
Old 04-18-2014, 07:36 PM   #6
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Please be safe and may God Bless you!
Old 04-20-2014, 01:04 AM   #7
HandOverFist
I seem to be in a perpetual snake bite loop with this car. One qualifying pass this morning and I was rewarded with a cracked transmission case. There has to be some misalignment or binding somewhere. Body bushings look tight and fine...going to investigate the motor mounts before another transmission goes back in. I marked the crack in the case so it would show better in the photo's.
Since I was pretty much useless for anything else I spent the day taking pictures and actually recorded every round. Too much video to upload in it's entirety, but I will put up part of a round and the final.
Due to my no-show for the first round Brian Rogers got a bye with his bad to the bone D/S 302 '69 Camaro...
Rich Taylor
I/SA - 321
