Old 04-13-2014, 06:22 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Update E-F/SA Bird Build...
Well, that blows...I won't whine anymore about my problems. No doubt you will get it squared away quickly.
Rich Taylor
I/SA - 321
Old 04-13-2014, 06:35 PM   #2
brent flynn
brent flynn's Avatar
Will get it done as quick as possible... i figure another 1k will get me to better than before...as long as piston didnt get hurt, or worse...
Old 04-13-2014, 07:15 PM   #3
Alan Nyhus
Liked 800 Times in 237 Posts
Sorry to hear...at least the motors still in one piece. How much valve-to-piston clearance did you have? -Al
"That'll never work....."
Old 04-13-2014, 10:25 PM   #4
brent flynn
.100+
Old 04-14-2014, 09:28 AM   #5
bob3240
Liked 16 Times in 5 Posts
Bummer, Brent. If you need anything, let me know. Are all the keepers intact?
bob3240 is offline   Reply With Quote
Old 04-14-2014, 05:03 PM   #6
brent flynn
Yeah, Bob, i had valve cover off at the track, and keepers all looked normal... gonna rip intake and valley cover off tonight...will keep you posted...
Old 04-22-2014, 06:48 AM   #7
brent flynn
Removed heads, #4 exh valve bent, as suspected... only went to 5700-5800.
Pulling shortblock tonight, to check #4 bearing, and make sure its not passing anything, as the filter was pretty clean, but, lifters already showing wear. Cam still looks fair. Also alot easier to degree cam, and i have a pan bolt, along passenger side, that is leaking a bit...( a first for me) ...Chris at Comp is gonna be working on a new grind for me, and we will figure out springs and lifters...Hope to be ready for testing, before Joliet.... fingers crossed...Piston had very small spot on it...
