Old 04-24-2014, 11:36 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Just got confirmation this morning that the 200 case was cracked as well. Even with all the components being replaced on this car I want to get as many eyes on it as I can before it goes back out. The builder of the new drive shaft reports that the old shaft was just slightly out of balance...I'm thinking it had little to do with our problems.
The following parts have been checked and/or will be replaced -
New drive shaft w/1350 yokes
New tubular transmission crossmember (will stick with the poly mount)
New solid motor mounts (both being equal height)
Sub-frame bushings checked for tightness
My best guess is the mis-matched motor mounts were the primary cause of most of the woes we have experienced...have yet to come up with a logical reason for someone doing that. I believe the original slapper bar traction device masked/cushioned the problem. With the introduction of the Caltrac's and the subsequent higher shock loads things began to fail. With everything in it's proper place and working together I predict some low 1.40's in 60' times. Btw, the torque convertor appears to be unscathed.
Rich Taylor
I/SA - 321
Old 04-24-2014, 11:52 AM   #2
FED 387
Liked 333 Times in 180 Posts
do u have the side stiffening bars on your trans case??? FED 387
Old 04-24-2014, 12:01 PM   #3
Robert Simpson
Liked 20 Times in 12 Posts
Rich, where did you get the tubular trans cross member from? Is it lighter? Or easier to install? Thanks
Robert Simpson is offline   Reply With Quote
Old 04-24-2014, 12:13 PM   #4
HandOverFist
Yes FED, but there is only so much they can do with my abuse lol!
New crossmember from http://srdparts.com/index.php?page=s...emart&Itemid=1
Appears to be a quality piece and it will help with the shift cable routing.
Rich Taylor
I/SA - 321
Old 04-24-2014, 02:47 PM   #5
Dion Hildebrandt
Dion Hildebrandt's Avatar
When you get all of these parts in place with the proper mounts and such ,spend some time measuring up your driveline angles. I suspect you may find that they may not be at ideal angles.
I say this only because of the violence you described with the diff situation, it reminds me of the troubles I had with my car. The root cause of my issues were the engine/trans and diff were doing this ( \-/ ) as an over simplified example. I kept knocking out driveline parts until we corrected that issue.
Nothing more frustrating than chasing a problem that hides in the shadows. good luck with the car
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-25-2014, 01:00 AM   #6
HandOverFist
The angles were perfect until the perch's collapsed...
Rich Taylor
I/SA - 321
Old 04-26-2014, 09:11 PM   #7
HandOverFist
Thomas Arnett comes thru once again. Drove to KY this morning with a buddy who is building a '68 Camaro E/SA and we picked up two identical fresh metric 200 transmissions. Everything is bolted back in the car with the exception of the drive shaft which should be in hand Monday. See you guys in Bowling Green May 18th.
Rich Taylor
I/SA - 321
