Old 05-04-2014, 01:05 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Went to the track today hoping for some good results...a mixed bag at best. The good news is I did not break anything and I did not require the use of the winch to load the car hehe.
The car repeatedly shucked out 1.50 60' times and ran 7.26's back to back. The car is leaving like the old Mopar's used to...straight out with barely any front-end upward motion. I believe I am now battling some type of carb issue as it just doesnt hit the tires hard like it once did. Don't believe it has anything to do with the spring or shock changes. The GoPro video shows nothing of real interest that I can pick out.
I had another camera pointing at the pinion, but the angle was ineffective rendering the video pretty much useless. From the above video it appears to get some pretty good rotation tho. I'll have to fashion a bracket to get the camera more in front and level with the yoke.
With only one lowering block installed the ride height is slightly higher than previous...figured I would let it ride for a bit to see if the new springs settle any.
Here are the old motor mounts I pulled out of the car. There was almost a 1/2" difference in height between the two...likely the culprit for the cracked cases.
I will keep at it until I find the bug.
Rich Taylor
I/SA - 321
Old 05-04-2014, 05:59 PM   #2
bigsixman
Liked 2 Times in 2 Posts
Good luck on getting your car dialed in Rich. I hope your breakage issues are over and it is just fine tuning the combination.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
Old 05-04-2014, 08:14 PM   #3
brent flynn
brent flynn's Avatar
What is your converter flashing to? its either the carb or the converter... didnt you do some 1.45's before?
Old 05-04-2014, 08:46 PM   #4
HandOverFist
I did not look at the tach yesterday...probably should have. If it turns out to be the convertor I may have to re-think this automatic deal.
Rich Taylor
I/SA - 321
Old 05-04-2014, 10:06 PM   #5
brent flynn
Sounds like it is too tight... you could always try different carb, to see if that is it... My $ is on the converter... didnt look like it spun any...
What brand are you using? The videos from your prior testing, looked pretty good...but you have changed converter since then, correct? Too bad you dont have a 350 turbo in there...probably easier to find a converter to swap in ... Atleast you made it down the track... I dropped heads off today...My new cam should be coming in , early this week...
Old 05-04-2014, 10:37 PM   #6
HandOverFist
Nope...same ATI convertor.
Rich Taylor
I/SA - 321
Old 05-05-2014, 06:16 AM   #7
brent flynn
put a 1/4'' stroker in it...nobody will ever know...hehe
