Old 05-31-2014, 01:44 PM   #241
Lanny Lehman
Lanny Lehman's Avatar
Liked 55 Times in 18 Posts
Send a message via AIM to Lanny Lehman
Default Re: '67 Camaro E/SA redo
Sir,
What master cylinder (part number, type and pushrod) did you use to replace the factory cast iron master cylinder?
Be blessed today!!! (Salvation through Christ Jesus alone (John 3:16))
Lanny Lehman
Lanny Lehman is offline   Reply With Quote
Old 05-31-2014, 01:52 PM   #242
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Originally Posted by Lanny Lehman View Post
Sir,
http://www.jegs.com/i/Strange+Engine...360TA/10002/-1
http://www.jerrybickel.com/brake-kit...-jbrc1064.html
A combination of Bickel's piece, theaded stud and threaded hex coupler. 4-piston Aerospace front and rear w/2# residual valve in the rear line.
Rich Taylor
I/SA - 321
Old 05-31-2014, 09:46 PM   #243
NHRA 303
NHRA 303's Avatar
Originally Posted by HandOverFist View Post
Thanks Alex for the offer, but there was a sudden turn of events this morning.
When my partner showed up this morning I had the housing ready to pull out. One thing led to another and we were headed to town to pick up his torch and welder. Long story short is the perches are repaired, reinforced and the housing is back under the car ready for battle. Plan on being back at Bowling Green this Saturday to pick up where I left off.
Had this almost happen to me too about a year ago. I was turning my drive shaft by hand. When it locked up on me. Which made my heart skip a beat. Opened the rear cover. And low and behold. Three teeth stripped off the ring. After only 20 passes. So im looking a little closer at the ring. And realize that its a "street gear" What the hell! This is a full race rear end. 40 spline axles, 5/8 studs, race brakes. The whole nine yards. So i gave them a call. And they just turned it back on me. "Well we really dont know what transpired when i ordered it". Are you kidding me. So anyway, the point to my quote. When i took the rear to have the new "RACE GEARS" installed. I noticed the same distortion happening to my perches. I just staightened them. And boxed them just like you did. Ive put another 50 passes on them without any problems. And i hit it them pretty hard. Im running a D/S 66 chevy II. If i get really motivated next winter. I might replace them with Caltracs. Moser's equipment is slightly cheaper. But they have a few screws loose working there.
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
Old 05-31-2014, 10:17 PM   #244
HandOverFist
Gawd! I really hated seeing those pictures again...
Rich Taylor
I/SA - 321
Old 06-01-2014, 11:29 AM   #245
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
For your info, this thread motivated me to spend the extra money and put an all Strange Engineering rear end setup under my 68 Mustang.
Dale
Dale Shearon
68 Mustang 6394
Old 06-01-2014, 11:39 AM   #246
HandOverFist
I would enjoy seeing that Dale.
Rich Taylor
I/SA - 321
Old 06-01-2014, 02:24 PM   #247
FireSale
FireSale's Avatar
It's about three weeks out. Just got the order completed Friday. I'll send some pics when it's in.
Dale
Dale Shearon
68 Mustang 6394
Old 06-01-2014, 09:17 PM   #248
Lanny Lehman
Thank you Sir for the information on the master cylinder!
Lanny Lehman
Old 06-01-2014, 09:23 PM   #249
HandOverFist
More than welcome Lanny. Btw, when I mentioned a hex nut I should have said a threaded hex coupler to be more precise.
Rich Taylor
I/SA - 321
Old 06-05-2014, 01:21 AM   #250
HandOverFist
Viking DA shocks installed...I'll let you know how they fare.
Rich Taylor
I/SA - 321
