Old 06-09-2014, 01:23 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 282 Times in 78 Posts
Default Re: RV fridge issue feezer cold fridge is not
Joe,
The freezer section should be -5 to no greater than 15. Also is the vehicle level while you are having these issues? Do you keep it turned on all the time? Ammonia refrigeration is temperamental and slow, but once it gets cooking look out. Depending on what thermistor you have, there is a chart that will cross reference resistance to temp. Typically a thermistor or temp sensor for that matter may be out of calibration or open. If you place the sensor in a ice water bath and then read the resistance that may be helpful. The 7000-10000 is a very broad range.
Sean
Sean Marconette
84 Mustang
5060 SS/N
