Old 06-22-2014, 04:44 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
It had been fifteen years since I last been to US 43 Raceway, formerly owned by Jim Butler. My only goal tonight was to get one of the Q-jets tuned to run decently...the hell commenced as soon as I unloaded the car lol. Neither of my two carbs would make a clean pass down the track...I was just about to the point of heaving them into the treeline.
5 minutes before first round I tore one of them completely down leaning the primary jets, stiffening the air door spring, taping the secondary rod slots on the gasket and installed CV rods on a K hanger. It made a clean pass, but the car was a real dog all night. Ended up going 8 rounds losing in the final. One of these days I will own a good Q-jet haha...
https://www.facebook.com/US43Dragway
There was a nasty nitro Fuel Altered on premises this evening...
Rich Taylor
I/SA - 321
Old 06-22-2014, 09:04 AM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, it looks like the mechanical gremlins are a thing of the past. If you could get a 'known good' QJet to try, that would answer a lot of questions.
Good job on getting to the finals! -Al
"That'll never work....."
Old 06-22-2014, 12:36 PM   #3
HandOverFist
Thanks Alan - It's still a mystery how the car could 60' a 1.45 at one time and we have never been able to get it back near that point.
Rich Taylor
I/SA - 321
Old 06-22-2014, 05:30 PM   #4
brent flynn
brent flynn's Avatar
Congrats on goin' 8 rounds! thats great!...yea, that is weird... 1.45s early in the year, and slowing down that much... find a known working qjet, and see what happens... i hope its not an internal deal, like a cam , or something... Your mph has fallen off a bit, too, as well, correct?
Old 06-22-2014, 05:37 PM   #5
brent flynn
what primaries, and what do the CV rods measure? are they like .052? I cant remember... i run 65 primaries, DA (.044) secondaries on K hanger... my flap is pretty loose and choke pulloff is about 1 second, and its adjustable... you need to contact Cliff Ruggles at Cliff's High Perfomance in Mt Vernon OHIO...
he sells adjustable pulloffs, and the best parts you can hope to find...and he is a master tuner... Call him, buy a few good acc pumps, an adjustable choke pulloff and anything else you might need...he will be glad to help you with some expert advice... He has been a huge help to my qjet adventure... Helped me get 1.44 60fts and 10,80s from a tired old 455 bracket engine... Cliff @ 740-397-2921 Mornings are best to get ahold of him, in my experience.
Old 06-22-2014, 07:56 PM   #6
HandOverFist
I've been on the site Brent, but have never seen those adjustable pull-off's you speak of. I would gladly try them.
Rich Taylor
I/SA - 321
Old 06-22-2014, 11:08 PM   #7
brent flynn
Give him a call... i have 4 of them...hehe Tell him Brent sent you... i dont discounts or anything, just want him to know that im spreadin the word...
Old 06-23-2014, 12:21 AM   #8
HP HUNTER
Liked 373 Times in 129 Posts
Unfortunately you've changed a lot of things since the rear end decided to go strait up, I have to ask, does the converter feel the same as it did before the rear end broke? How about drive shaft angles, it probably doesn't take much to lose your combination.
Old 06-23-2014, 12:42 AM   #9
HandOverFist
You are correct...I'm learning that all the stars must be aligned for one of these cars to perform as intended. I've put the car back to it's previous state as far as I can remember. All angles are still the same and the convertor was cut open/inspected. There was a slight tweak to get a little more stall, but I can't tell any difference in the way it feels. I have yet to change the way I stage/stall the car. I'm beginning to suspect that those carbs were running very rich all along and coupled with good cool air earlier in the year was the reason for the good 60' times then. I guess the summer air was a death blow for the way these carbs are set up. I have one unmolested Edelbrock Q-jet I'm working on atm and will try to set it up very lean for this summer heat.
Rich Taylor
I/SA - 321
Old 06-23-2014, 07:47 AM   #10
HP HUNTER
Who cut the converter? Difference in Baro and DA from Spring air to current air? What temp do you leave at? When you changed the drive shaft was there a weight difference? Always weigh every thing in the drive line, I can only imagine how critical that would be in a setup like yours.
