Old 06-29-2014, 08:29 AM   #1
BTR69
BTR69's Avatar
Liked 85 Times in 26 Posts
Default Re: Shock recomendations, 68 Camaro
Thanks Rick. I have considered using a stock repacement from the local parts store. We will likely be making a few improvements as the year goes on & next year to go a bit quicker which has me thinking of using something more race specific. You're correct, it doesn't hit the tires hard at all right now. It still works ok with whats on it now, just makes a lot of noise going into gear & whenever I go over any uneven surface. I only stage it up to 2500 right now. Brother does have a spare engine that needs freshening up that would definitely wake the car up. As long as I don't hurt what's in it now, that one will likely go in next year & would likely drop our 1/8 mile ET by at least 1 second.
I like the red paint, Koni impersonator, idea, I think it would look good under this car. Maybe add a little intimidation factor too?
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 07-23-2014, 10:08 PM   #2
rick lester
Liked 4 Times in 1 Post
Anything to report?
I was thinking about shocks and suspension the other day......way way back in the early 80s, I met the late Lee Sherman, which by the way is one of my racing heroes, we talked about his car, if I'm not mistaken a H/SA 1969 Camaro, maybe I/SA. Anyway, his car ran 11s, no frame connectors, 8 point rollbar, 6 cyl. front springs, mono rear springs with 90/10 shocks, drum brakes on all four corners. Lee Sherman was one of the greatest in Stock, he took the time to talk to me, answer any questions I had no matter how stupid they were, never looked down at me just because I was 13.
Why am I telling you this? You don't need expensive shocks and suspension peices under your car to be a racecar, simple parts, lots of research, a few bucks, and you too can have a very well put together racercar for alot less money than you think.
rick lester is offline   Reply With Quote
Old 07-24-2014, 09:22 PM   #3
BTR69
BTR69's Avatar
A couple weeks ago I pulled the existing shocks off. Even though they look like hell, they seem to extend & compress nicely on the bench withough any issues. I'm beginning to think it's something in the pinion area. The thumping is the same as when I had a bad shock bushing in one many years ago. With shocks on or off, I can bounce the rear up & down without the thumping. The U joint appears good by just looking at it & it doesn't appear to have any play in it, but I hear a similar thump, just not as loud, at the pinion when I rotate it by hand. I haven't had time to spend on it so it's been sitting waiting for me to get back on it. The only time I hear the thumping is when driving over any size bumps in the road. The return road can just about give you a headache with all the high - low spots & noise it creates. It's going to stay parked until I can be sure it's not going to come apart. Going to cross my fingers it's the U joint at this point. Hopefully in the next couple weeks I'll be able to spend some quality time with it again. Thanks for the tip with the 90/10's. I priced some, just haven't bought them yet.
William Kilduff
1968 Camaro SS/C
