Old 06-29-2014, 11:04 PM   #1
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
Mark, it seemed to pull all the way through the lights...being 11.59/115, the mph was good , for the ET, and at only 5800-5900. I figured the valvesprings would give me the ability to shift 1-2 at 6k, instead of 5800, if engine likes it, and also 2-3 shift as well, and would let engine pull to 6500 quickly. THe springs i had on it, for the 1st outing, were about 135 or so on the seat, and around 300 open, and they were really for a solid cam , that we used to run( .588 lift ). Im adding 80# to the car, to make 'F' weight...may not need all 80#, but i know im needing around 60#. Figuring on scale inaccuracy... The weather is supposed to be fair, this Wednesday...so we will see what it does. The converter flashes to 4800 in high gear, and i would imagine if im shifting much less than 6k, im not keeping it locked up...
Old 07-03-2014, 11:06 PM   #2
brent flynn
Well, the gear was way too much... hehe... 11.566/114.30 with 1.523 60' and 7.29/92.xx 1/8 mile. All were gains, but car was running 6700 thru the traps... felt dead all the way down the track. The engine is strongest around 5800-6000, so decided to go with the 4.56s, hoping to keep trap rpm around 6300 and make more use of the torque on the 1-2-3 shifts. I will have to start playing around with little things... The runs i made , were all with 80# added weight...The runs with the 4.30 gears, were not. Air was real good, but couldnt take advantage of it, with the 4.88s. Got home last night at 8:30 and ripped it down... Got it all finished tonight, and in the trailer, for some 1/8 mile July 4th Pro action . I will run it out the 1/4 mile to see what it traps at...
Old 07-04-2014, 01:13 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I don't know Brent...you did add 80 pounds. Were you shifting at the same rpm as before or did you up the shift points as well?
Rich Taylor
I/SA - 321
Old 07-04-2014, 09:17 AM   #4
Kegracing
Glad it is on the track and making some passes. Keep tweaking and taking notes.
Good luck, and hope it is a good 4th.
Ken
Kegracing is offline   Reply With Quote
Old 07-05-2014, 10:56 PM   #5
brent flynn
The engine liked 5700-5800 on the upshifts and pulled through nicely at 6300, but since they were only running 1/8 mile, i didnt get times for the 1/4... goin
up on Wednesday to do some tweaking...
Old 07-06-2014, 12:09 AM   #6
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Brent, glad to see things are coming around. This is a interesting thread with some really smart guys chiming in. Tommy.
Old 07-06-2014, 06:51 PM   #7
bob3240
Liked 16 Times in 5 Posts
Glad it's coming around Brent. Looks good leaving the line. (What was that ole car behind you lol)?
bob3240 is offline   Reply With Quote
Old 07-07-2014, 10:21 PM   #8
brent flynn
THanks Bob! Gettin there slowly... That '62 Grand Prix belongs to Gene Gabbard of Centerville/Richmond area...it runs high 10's ...
Im taking Bird Wednesday eve to do some tuning...havent done any tuning yet...just changed gears twice and put good valvesprings on... same jetting, timing, oil, as i started with. Gonna work with header collectors too...I hope to find some 11.30s, or better...
Old 07-04-2014, 07:15 PM   #9
tommy d
tommy d's Avatar
Hey, take it easy on that Dillman kid in the black Camaro this weekend!
Old 07-05-2014, 10:46 PM   #10
brent flynn
Well, i made 5 nice runs yesterday... in order .. 7.29/7.27/7.27/7.29/7.29... I had a quick miss on 1st pass...turns out i had a loose connection on coil wire terminal... the 2 7.29s were in the heat of the day... 4.56s worked perfectly... 6300 at 1/4 mile and 1.526 best 60'. they were all around there ... 1.535 , i believe was the slowest... shifts were made at 5700-5800 ... Now, time to start tweaking... i had headache yesterday, so i wasnt good on the tree....
here was my 1st pass of the day..
