Old 07-16-2014, 03:19 PM   #1
FED 387
Liked 336 Times in 183 Posts
Default Re: Bounder, cruise won't work
On that vacuum pump you should be able to hear it runnning with the engine OFF & the ignition turned to ON!!!
Old 07-16-2014, 03:47 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
OK, wasn't sure what type of cruise system they used on these, never considered a vacuum unit. Thanks. Joe
Joe Buchanan SS/BX 3117
Old 07-17-2014, 02:38 PM   #3
buzzinhalfdozen
Well I found something, not sure if it's the fix (I'll know tonite) under the floor is the air brake valve it has 3 switches on it...found 1 wire off (corroded wasn't a sealed end) . Anyway it goes into a harness that runs into the coach (with about a thousand others) hoping it's the wire for the cruise. Suspect it is a power or ground input for cruise.
Old 07-17-2014, 02:55 PM   #4
FED 387
Joe --find a heavy duty truck repair tech and see if he can shed some light on the air brake system pick his brain--- I'm out of suggestions / ideas ---I'm just a retired office guy that has repaired my own stuff for a long time
Old 07-21-2014, 09:40 AM   #5
buzzinhalfdozen
Yeah thanks, that wire didn't make the cruise work so now I'm wondering what it was for. Thanks for the suggestions I'll keep looking and see if I can find a good heavy truck tech.After making a few calls to local RV and truck garages I think I missed the boat on careers.... been quoted between 3-5 hours to diagnose @ 120.00 per hour WOW! At my job I'd better have it properly diagnosed in an hour or less or they're crying like babies about why it takes so long. I've no doubt I'll get to the cause of the problem.
Old 07-21-2014, 11:39 AM   #6
FED 387
OK Joe --After talking around to my friends several have brought up this company's name try these people
WWW. CRUISECONTROLKING.COM
507-334-0250
Cruise King LLC.
22250 Glynview Trail
Faribault, Minnesota 55021
look at their website they have some trouble shooting tutorials for the different methods of engaging cruise controls paddle, stalk ,steering wheel etc THEY ALSO HAVE SCHEMATICS FOR THE DIFFERENT TYPES OF CONTROLS--- plus other things to look foralso call them/tech they can maybe help you diagnose it yourself lotsa people have mentioned their name so happy hunting you just might get it repaired cheaply or they sell complete kits also-- Regards FED 387
Old 07-22-2014, 07:59 AM   #7
Kirk Morgan
Liked 81 Times in 45 Posts
I have installed a few aftermarket cruise controls over the years. The two most common problems are vacume leaks, and speed sensors. Most older ones use magnets for the sensor for the cruise. If I has a pod for the throttle these would most likely be the case, also adjustment on the pull cable.
Kirk
Kirk Morgan is offline   Reply With Quote
