Old 08-22-2014, 04:22 PM   #1
FED 387
Liked 336 Times in 183 Posts
Default Re: 2000 Ford F250 Diesel air cond problems
TWO WHEEL drive !!!
Old 09-03-2014, 01:44 PM   #2
FED 387
Question Re: 2000 Ford F250 Diesel air cond problems
OK finally got around to replacing the pump with a known good pump--- still sameo sameo still defrost only---pulled the glove box out looked under there nothing looks bad---possibly the "selector" is bsd???---without tearing the whole dash apart anyone got any other suggestions?? Thanx FED 387
Old 09-03-2014, 02:10 PM   #3
FED 387
Angry Re: 2000 Ford F250 Diesel air cond problems
I just checked and the A/C compressor is also engaged in any position except off-- not matter which position the selector is in EXCEPT off the a/c compressor is running
Old 09-03-2014, 04:30 PM   #4
1965
My 2001 F350 dsl dually had a canister on left side facing motor near ac box on the firewall the bottom of it had a pinhole that caused a leak so ac didn't come out of vents but defroster only= the canister is about the size of a quart bottle with vacuum lines running to it hope this helps bobby
1965 is offline   Reply With Quote
Old 09-03-2014, 05:46 PM   #5
FED 387
Yep know exactly where it is thought about checking that too-- with all the vibration and the age of the truck makes sense the plastic finally gave out ---how did you locate the pin hole what test did you use???
Old 09-04-2014, 09:35 PM   #6
1965
Kind of right behind the battery, mine I could see the pin hole , all u have to do when u pull off is pull vacuum or blow air into it, u can by pass the canister with the vacuum hoses to see if cures the problem then search for leak in tank
Old 09-10-2014, 02:41 PM   #7
FED 387
OK--so far I have replaced the pump and the reservoir with a known good pump & reservoir--- chased down all the vacuum hoses none appear to be chafed or worn--- how about the control selector on the dash anyway to test it ? or do they just "go bad" looks like its all plastic so no way to take it apart the hose is fastened to the selector not hanging or anything- changing it from any position to another( vent/AC/heat/defrost) changes nothing STILL ONLY DEFROST !!!-- looked under the dash/glovebox area nothing appears out of the ordinary there---any suggestions other than replaceing the selector knob---truck is 2 wheel drive and has AC---thanx FED 387
