#151 |
Liked 33 Times in 16 Posts
I elected to use the spring compressor today and the 4-cylinder springs went in easily. A-arm's don't swing as easily as I would like with these poly bushings, but they are not too bad. Front is done with the exception of Aerospace rotors and 4-piston calipers which are on the way...decided to use the same set-up as the Camaro. Finally snaked the front sway bar out of the car...geez what a chunk of metal. I'll be pulling the engine out in the morning and install the manual rack shortly after.
Rich Taylor I/SA - 321 |
#152 |
Liked 19 Times in 12 Posts
How much did you tighten the bolts? I left my bolts snugged up a little them double nutted them. Wasn't bad that way at all. Project is coming along nicely.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#153 |
I can probably back them off a little and add some nyloc's Mitch.... wanted some bearings but could not source any. Front sits well, just hoping the springs will let it separate easily.
#154 |
Liked 372 Times in 130 Posts
Looks good Rich.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#155 |
Liked 251 Times in 125 Posts
Gotta be careful with that. I was going to do that on my car, but I felt it would egg-shape the holes over time, as now the arms will pivot on the bolts and holes as opposed to the bushings. Possibly okay on a drag-only car, but I would inspect it regularly. I didn't do it because mine is a street-strip car and I felt they would wear too quickly and unnecessarily. Egg-shaped holes are a pita, street or strip, gotta weld and dress.
#156 | |
#157 |
Finally out of the hole. Manual rack and front brakes in the morning.
#158 |
Liked 237 Times in 126 Posts
They sure put a lot of messy stuff under the hood of stocker don't they?
Dale |
#159 | |
It was a bit of a battle by myself...amazing how quickly things let go when you break out the die grinder/cut-off wheel. The one redeeming feature of this car is when you pull the transmission the engine doesn't drop backwards like it does in the Camaro...sits perfectly level on the K-member until it's plucked out.
#160 |
Liked 240 Times in 112 Posts
If I could back up just a bit. How difficult was it to replace those control arm bushings ? I need to do that to my Cougar.
Dave Noll, EF/S ,?/SA 6526 |
