Old 12-01-2014, 09:45 PM   #1
Kegracing
Default Re: Woodfin's SS GT/TB construction series
I love racecar porn!
Looks more like Christmas came to your house early than Thanksgiving... but sure you are thankful!
Keep going Larry.
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 12-01-2014, 10:26 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Ken,
let's try for 25 days of shiny parts
Larry Woodfin 471W
Old 12-01-2014, 10:57 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Woodfin's SS GT/TB construction series
Originally Posted by Dragsinger View Post
Ken,
25 days,, eh? Sounds like a Christmas song to me,,,, I'll start it off, you keep it going.
"On this first day of Christmas, Manley sent to me,, 8 rods connecting,,,( I couldn't help myself)
Danny Durham
Old 12-01-2014, 11:05 PM   #4
Dragsinger
Danny, stand by, you have started something
Larry Woodfin 471W
Old 12-02-2014, 09:06 AM   #5
Dragsinger
On the second day of Christmas the warehouse sent to me, coated bearings for my Cheveee
Larry Woodfin 471W
Old 12-02-2014, 10:53 PM   #6
Dragsinger
On the third day of Christmas the freight truck brought to me, some shiny parts from BTE.
Several things of note;
*The input shaft has a single Teflon sealing ring. In addition, it has two grooves that allow fluid that is leaving the converter to easily flow past the stator bushing.
*Also note the light weight direct clutch hub and dual sealing ring servo piston.
BTE is a good company doing a good job for Sportsman racers.
I like quality,shiny BTE parts
Larry Woodfin 471W
Old 12-03-2014, 08:24 PM   #7
Dragsinger
On the fourth day of Christmas the parts truck brought to me, four control arm bushings.
We have several options with upper control arm bushings for the Super 10. With past buildups I have experimented with some of those options.
For this project I am using factory replacement bushings by Moog. The photo shows a minute spent with die grinder and disc grinder to remove the internal serrations.
Checking the photos you see the control arm shafts have threaded ends. This is common to may GM front suspensions.
When completing the assembled arm I used chassis/wheel bearing grease between shaft and bushing ID. On the end of each bushing I applied silicone rubber lube to bushings and retaining washer.
Then, self locking nuts are run down to tighten the assemble then back off ever so slightly, about 1/16 turn.
The result, control arms move smoothly on the shafts with very little resistance.
ID:	26471   Click image for larger version
ID:	26472   Click image for larger version
Larry Woodfin 471W
