Old 12-10-2014, 11:35 PM   #31
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
In keeping with the idea of have several systems underway at once, these two photos are of the converter priming valve in the trans front pump.
The roll pin is 1/8 single wall which is fine for factory usage but holds potential to shear under higher pressures of racing.
The upgrade is a heavy duty, multi-wound roll pin. A common hardware store item.
Tomorrow "some" system will some progress
ID:	26523   Click image for larger version
Larry Woodfin 471W
