Old 11-01-2007, 05:50 PM   #1
luckydog
luckydog's Avatar
Default Re: Trans brake 350 turbo
I think what he means is that the trans brake is not engaging quick enough. I think this problem is kind of inherant of 350's. I've ran a couple of them. This is how I cured the problem. When bumping in with the brake pedal engage the transbrake each time you take a bump. In other words, transbrake and footbrake at the same time, each bump. This solved the problem for me, however I was running no-box and didn't have any delay. Delay would make it a little tougher to do. A throttle stop would make it darn near impossible. If the piston in your transbrake silenoid is adjustable, lengthening it would also help (once too long the car will back up). Also could try bringing you RPM up when staging.
luckydog is offline   Reply With Quote
Old 11-06-2007, 10:46 PM   #2
joker
Thanks for all the help I put a powerglide in.Way faster so far so good now I have to figure out how to set up timers I have been told to shift into high as soon as possible. Will have to figure out in spring. Thanks
joker is offline   Reply With Quote
Old 11-27-2007, 01:06 AM   #3
joker
Default Re: Relplaced 350 trans with glide
I am using 1.80 glide I shift on time I am running in super street any suggestions on timer setting to get close. I know I will have to fine tune.Car is 85 camaro weight is 3000 runs 10.10 wide open 134mph sure am sick of winter and it has not started.
Old 12-04-2007, 10:57 PM   #4
Dennis Paz
Liked 5 Times in 3 Posts
.010 in timer 1
2.50 in timer 2
shift at 3.50
1500 rpm downpower should get you close.
Dennis Paz is offline   Reply With Quote
Old 12-05-2007, 09:48 PM   #5
joker
So you don't think getting into high gear before you go wide open will work? I was told to get into high gear before you go wide open.
Old 12-06-2007, 12:07 AM   #6
Dennis Paz
I have 2 cars that run 9.50 in s/st trim and I shift both cars after full power. The only time I wont is if I think the track is junk. I have found the car more consistent this way. What throttle stop are you using? air or electric? I use dedenbear electric with no problem.
Old 12-08-2007, 01:02 AM   #7
joker
I have air K&R pro cube which is great I also use the pro stage. I will try your numbers it is about where I was last race, first time out with powerglide made it to semi's racing super pro. I used 350 for 2 years it was fine but not good in super street trans brake was to slow. Thanks for your time
