Old 01-27-2015, 06:41 PM   #11
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Ol' Fart's Firebird Fantasy
Originally Posted by impstocker View Post
I think what Tony means you use the roll bar as a way to strengthen frame. I have lower crossbraces to that crossmember that tends to pull out. I also replaced rubber body bushings with solids.
Will Lamprecht I/SA Impala 1965 in progress
That's what I was referring to. Roll cage to tie together and prevent frame twist, then anti roll bar to prevent suspension twist. Obviously solid bushings to help stop suspension movement (and body bushings too, as you stated). I also prefer adjustable shocks for fine tuning. Some of this is referring to coil spring cars in general, (my Mustangs), while some of it is from previous A bodies, I have owned. (Monte Carlo, several Chevelles). These are my choices, others may have a different opinion.
Tony Corley is offline   Reply With Quote
