Old 02-05-2015, 11:02 PM   #1
RJ Sledge
Liked 292 Times in 92 Posts
Default Re: Piston/Ring issue???
I mic'd the rings and spacers and they checked, but had no way to really check the ring groove width or flatness. I ran a .059 pin around the groove and felt no tight spots, but I am thinking the grooves might not be perfectly flat.
Thanks
RJ
RJ Sledge is offline   Reply With Quote
Old 02-05-2015, 11:19 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Just for my education, can I ask what your particular combo cost's ?
Dave Noll, EF/S ,?/SA 6526
Old 02-05-2015, 11:46 PM   #3
RJ Sledge
Way too much!!
RJ
Old 02-06-2015, 12:15 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
RJ,
I sure am glad you called today to discuss this problem. I still think they have a wave to the groves. I was just about to pull the trigger on a set of pistons for a Drag Pack customer. Since there are only 2 different companies that are approved I think I will choose the other. Not because of the problem, but because it wasn't taken care of. At this point I'm very glad I have procrastinated on ordering parts for this build. Like I said when we closed our call... Thanks, I think?? ;~)
Adger Smith (Former SS)
Old 02-06-2015, 01:22 AM   #5
RJ Sledge
Adger
Like I told you today, The piston people told me they found nothing..... the ring people said they would call me back today and I never heard from them. Sort of makes me nervous.
At this point I feel like the "Rat caught in the trap, really don't care about the cheese anymore,.....just want out of the trap!!
So I don't care who or what is wrong, I just want it be fixed so I can put this thing together.
Later Bud
RJ
Old 02-06-2015, 11:51 PM   #6
George Mirza
It's possible there is a small radius at the bottom corner of the ring groove. If the rings have a sharp square edge, when the seat in the bottom of the groove this could cause this rotation problem. This could be as small as .001-.002 radius and not visible to the eye. Is there a chamfer on the inside edge of the rings and spacers?
Interesting, keep us posted.
George
George Mirza is offline   Reply With Quote
Old 02-07-2015, 12:08 PM   #7
Jeff Stout
Liked 706 Times in 283 Posts
RJ Could you make a straight edge the same thickness of ring groove or a ,001 less and walk it around groove to find a sticking spot. I did this on a nitrous piston that had a problem of stuck ring. Couldn't see it by eye but found it with straight edge in groove when rotating it around piston. Ring groove was wavy as suggested by someone else
