i cannot get a straight answer for this .does anyone run stock elim and put gauges in a pillar pod setup and is it allowed ?all the factory stuff is still in the car like they want but i would like better gauges in a better spot . thanks
Liked 56 Times in 27 Posts
rick978,
Check with your Tech guy , he will give you the right info & save you time / $$$.... Good Luck....
Dave Ribeiro 1033 STK |
Liked 129 Times in 59 Posts
Have you spoken to Ryck Campbell, the Div #1 Tech Director? His number is 315-335-8295 on Monday and Thursday evenings from 7-9 PM. He's a good guy and should be able to help you answer your question. Just speaking for myself here, but I've seen a lot of folks mount their tach's on the A-pillar with no complaints from anyone!
Good Luck!
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 275 Times in 76 Posts
It should not be a problem. We are allowed to use a digital dash. Mine is a DataMaxx and is mounted in front of the original gauge cluster. It's cheaper in the long run than multiple gauges, that in an a-pillar may not be big enough to see. Just a thought. What year car are you running?
Sean
thanks guys i will call him asap
Liked 61 Times in 25 Posts
As far as seeing them, they make the gauge pods for 2 5/8 gauges, and it's a great location! I have ran them in several cars, but unfortunately none were stock eliminators cars, so can't answer the question on if it's legal. With that being said, I can't imagine why it would be an issue, not really any different than mounting them anywhere else in the interior as far as modifications are concerned.
Liked 1,604 Times in 583 Posts
As long as you keep the original OEM full stock dashboard, including OEM instruments, fresh-air ducts and controls, you can add any other gauges such as tach, oil pressure, etc.. in any location inside the car.
talked to div 1 tech and he said no problem with gauge pod
thanks everyone for the help not that we will be racing anytime soon with all this snow we are getting come on springtime |
Are the gauge pods custom fit to a particular vehicle or are they one size fits all? My driver which is a Buick has no gauges at all just idiot lights. I would like at a minimum to put in at least a temperature and oil pressure gauge. A pod would be nice because I am limited as to where I can mount them.
Nelson Kowal Stock 345 |
#10 | |
If your Buick is a G Body, Autometer and others have the pods. |
