Old 02-16-2015, 08:42 PM   #6
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Default Re: Dana 60 gear issues
Originally Posted by Jim Hawkins View Post
Richmond pro gears, tried syn. and regular gear oil. MW did the last set up and I believe backlash was at .012. Seemed a lot to me but that's what they do. I had a 12 bolt pinion bend in a big block car years ago but this problem appears to be the ring gear teeth. Tight spots random on the ring gear not consistent with the location of the pinion.
I wonder about the quality of the gears, are Richmond made offshore now or at the time I bought these? Next set will be 6.17 and do not know if anyone else makes these in a pro gear or if any treating would help. Not a lot of options with dana gears.
I dug out a couple of articles from the 70's on setting up a Dana 60. One was in popular Hot Rodding called Race Prepping the Dana 60 the other was 20 questions about the Dana 60 but were afraid to ask(October '74 Car Craft). These were in the heydays of Modified Production. One article recommended .002 backlash the other said .006. My 6.50's were set up at .004 and are still in fine shape. My combo is a 265 WCFB so not a ton of torque like yours.
I believe .012 is too much especially for a stick car and doubt if anything can be done with those tight spots in your existing gears.
Allan
55 Chevy is offline   Reply With Quote
