Old 03-01-2015, 11:03 AM   #14
qtrmile2
qtrmile2's Avatar
Liked 9 Times in 4 Posts
Default Re: 1967 camaro A/S project
Originally Posted by Danny Ashley View Post
I like the look of the carbon fiber roll bar protector bit I'm not sure if it meets the rule book specifications for padding. It reads: Adequate padding must have minimum1/4-inch compression or meet SFI Spec 45.1. I don't see how carbon fiber can be used as a padding as it doesn't compress. The Bickle site doesn't say this protector meets the SFI spec. I can see using it on the side bar to protect from scratches, but not in the head area as it offers no protection. Am I missing something here?
Danny, You only need padding on the roll bar if your helmet is 6 inches from contacting the roll bar only.We have 45.1 in that area of contact. Type of padding depends on ET. The carbon fiber used is not 6 inches from helmet. Hope this helps. It is in the rule book too.
Tostoracing
Retired S/ST and Stock owner/Driver
Div. 5 Tech certification team
qtrmile2 is offline   Reply With Quote
