Liked 61 Times in 25 Posts
I would also change to a much smaller crank pulley.
Liked 33 Times in 16 Posts
What effect would that have on charging Tony? I'll be using a stock alternator for the time being.
Rich Taylor I/SA - 321 |
#3 | |
![]() ![]() I still have this complete charging setup sitting on the shelf with intentions of using it on the Stocker when I get back too it. Last edited by Tony Corley; 03-17-2015 at 10:54 AM. |
Liked 204 Times in 54 Posts
Who makes that crank trigger arm?
Liked 1,586 Times in 583 Posts
ATF Speed makes the crank trigger bracket and timing pointer now.
http://www.atfspeed.com/store/index....products_id=96 |
There are several companies that make them with the adjustable pointer, and they are all pretty nice. The Reichard Racing guys did things on another level. I wish they still were making automotive parts.
Liked 50 Times in 23 Posts
Rich,
Had the same problem with the short water outlet and my ATI damper. Problem solved... http://www.summitracing.com/parts/csi-908L Cheaper than changing the damper .... Hope this helps,
Steve Stickel 1161 Stk 1167 SS |
#8 | |
Liked 237 Times in 126 Posts
Rich: I spent the extra bucks for a clockable Moroso water pump and was able to rotate the outlet out of the way. on mine it blocked the view of the timing pointer. Dale Last edited by FireSale; 03-17-2015 at 12:03 PM. |
Thanks Tony...I will look into some pulleys then. I can see it is a very small diameter because it bolts on from the outside instead of the inside of the pulley. With this alternator bracket it will be a very short belt.
Dale - My timing pointer is at the 10 o'clock position. The clockable feature would have eliminated the dampner interference tho.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-17-2015 at 12:40 PM. |
To SSGT. That was a Reichard Racing crank trigger set up. My understanding is that they no longer do automotive pieces after getting a large military contract. Not 100% certain on that.
Firesale, the engine had about 40 passes and several dyno pulls on it when that pic was made. Plus had been blown up once, (broken rod) Rich, it will be a short belt with the low mount alternator you have, lol. Last edited by Tony Corley; 03-17-2015 at 12:46 PM. |
