#301 |
Liked 33 Times in 16 Posts
What effect would that have on charging Tony? I'll be using a stock alternator for the time being.
Rich Taylor I/SA - 321 |
#302 | |
Liked 61 Times in 25 Posts
![]() ![]() I still have this complete charging setup sitting on the shelf with intentions of using it on the Stocker when I get back too it. Last edited by Tony Corley; 03-17-2015 at 10:54 AM. |
#303 |
Liked 204 Times in 54 Posts
Who makes that crank trigger arm?
#304 | |
Liked 237 Times in 126 Posts
Rich: I spent the extra bucks for a clockable Moroso water pump and was able to rotate the outlet out of the way. on mine it blocked the view of the timing pointer. Dale Last edited by FireSale; 03-17-2015 at 12:03 PM. |
#305 |
Thanks Tony...I will look into some pulleys then. I can see it is a very small diameter because it bolts on from the outside instead of the inside of the pulley. With this alternator bracket it will be a very short belt.
Dale - My timing pointer is at the 10 o'clock position. The clockable feature would have eliminated the dampner interference tho.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-17-2015 at 12:40 PM. |
#306 |
To SSGT. That was a Reichard Racing crank trigger set up. My understanding is that they no longer do automotive pieces after getting a large military contract. Not 100% certain on that.
Firesale, the engine had about 40 passes and several dyno pulls on it when that pic was made. Plus had been blown up once, (broken rod) Rich, it will be a short belt with the low mount alternator you have, lol. Last edited by Tony Corley; 03-17-2015 at 12:46 PM. |
#307 |
Rich, here you go. May can find it on Ebay or somewhere else for less.
http://www.uprproducts.com/mustang-3...pulley-79.html Last edited by Tony Corley; 03-17-2015 at 12:59 PM. Reason: Found better source |
#308 |
I need to correct myself. My pointer is a 10 o"clock install, too. The original outlet jammed the alternator and the second option blocked the pointer view. I did origami with the water hose to get things right. My mistake was to get a radiator with an inlet on the same side as the pointer. First time builder here...
Dale |
#309 |
#310 | |
![]() Dale - I've made numerous mistakes with this build being Ford ignorant lol. ![]()
