Old 03-28-2015, 09:22 AM   #5
rboyle
rboyle's Avatar
Liked 591 Times in 163 Posts
Default Re: 1973 Nova I/SA Chasing the Dream
Made 8 runs on Thursdays test n tune and never got the car under the index. Chased bad radiator hose, changed plugs, fixed broken two step wire and timing among other things. During qualifying ran 12.45 on the 12.30 index and lost in class obviously. Checked for broken valve springs or rocker arms and found the valves were out of adjustment by about 20thou. Adjusted and was desgnated pair #3 for Saturdays first round elims. Car started vibrating in second right at 5000 rpm checked tach checked oil pressure 50 lbs thought maybe valve float or rev limiter was funky short shifted third to see if it cleared up and bang boom bam. Rod kicked out the oil pan and trans case cracked and driveshaft spit out. Dream turned into nightmare. Picking up the pieces thanks to the great friends involved and starting over.
