Old 04-16-2015, 10:20 AM   #1
Keith 944
Keith 944's Avatar
Default Re: No trans brake in pro et
Originally Posted by theman440 View Post
Just don't use it @ the line.
As captain obvious stated, if you are not in the northeast, the electronics rules may not apply. here is what is allowed in div 1. (some tracks have their own policy)
Taken from the Northeast Division Schedule, Rules and Regulations:
17. Pro Eliminator (9.00-17.99) will be a NO-electronics class. Electronic ignition and single-stage (high side) rev-limiter will be accepted. Non-drive wheel line-locs will be accepted but wiring must be direct and traceable. Nitrous, must be activated by driver switch or wide open throttle switch, single stage only, no timers. Electronics expressly forbidden, but not limited to: data recorders, transbrakes, electric/automated shifters other than factory, two-steps, electronic throttle stops, and delay devices. Reverse Trans solenoid may only be operated by a switch affixed to the shifter, such as a back up light switch.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Keith 944 is online now   Reply With Quote
