Old 05-01-2015, 08:56 PM   #22
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Ford vs Chevy Build-up
Rich,
Also make sure your injector ground is connected to the engine and your engine has a good ground strap to the firewall. EFI needs good grounds! The main computer ground should be clean and tight as well and should be on the driver side front inner fender below starter relay.
The ground for the injector harness usually goes on a upper bell housing bolt.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
