#451 | |
Liked 251 Times in 125 Posts
I agree with the others, Rich. The can ran well. Everything is still intact. You're not far away. As they say, "If it were easy, everyone would be doing it". |
#452 |
Liked 79 Times in 11 Posts
very nice for the first time out with it. if you can take it to a chassis dyno you can tune it easier. if someone sits in the passenger side and reads the screen while you do the run on the dyno run it goes a lot faster. congrats and good luck!!
bob beals 7244 |
#453 |
Liked 5,139 Times in 1,962 Posts
Rich, Why were you running the car in N, if I might ask?
Natural O car that makes P. How much did it weigh?
#454 |
Liked 33 Times in 16 Posts
Thanks to all for the support...I'm headed out the door in a few minutes to go tear into that rear-end.
Mark - The car was light last night as I expected it would be...3165 pounds. Running it in N we were 123 pounds light...O would have been 230 pounds shy. Had I known what the car was going to do I could have run it in P and at least been able to run the index lol!
Rich Taylor I/SA - 321 |
#455 | |
My 1980 HB was 300 # light when I got it done. I had done the research and built a permanent 100# into it before I even started bolting weight in. I would recommend at least O/SA with it. Of course a lot of your data from last night would be skewed by adding that much weight. But then ,if you weren't making any power anyway, due to electronics, maybe not. I'd say tune the computer first, then put the weight in it for O, then start over.
#456 | |
Disassembled the rear-end today and found nothing terribly wrong. Ring/pinion is smooth and easy...with rotor/pads bolted up it requires a little more effort to turn. Surprisingly the greatest resistance to movement is from the driveshaft. Even removed from the pinion flange it is strangely difficult to turn in the normal rotation...fairly easy turning backwards (trans in neutral). I believe the vibration I felt on the first pass was simply the solid upper control arms in the torque boxes (no bushings). I'll do some more tuning on it, but I fear the engine might not be capable of producing the required hp in it's current state...we shall see.
#457 |
I figure about 280 hp would put you .2 under in O.
1 hp per cube isn't really too hard with a Stocker cam. Those cars will go mid 14's through the mufflers with 3.73's and stock converter, AOD with 200 ,000 miles on them.
#458 |
Yes, I was surprised how poorly it ran the first pass until I returned to the pits to review my...ahem...recording. Perhaps I will get a handle on it soon.
http://vid434.photobucket.com/albums...psdijd3mza.mp4
Rich Taylor I/SA - 321 Last edited by HandOverFist; 05-11-2015 at 02:39 AM. |
#459 | |
Converter goes right to 5 grand? Sounds about right ..for starting point.
#460 |
Liked 204 Times in 54 Posts
What do you have for a first gear in that trans?
