Old 05-21-2015, 11:45 AM   #491
hutt1
Default Re: Ford vs Chevy Build-up
did you look at the procedure to set the distributor at sbftech? if you set the distributor like a crank trigger it will run but not not perform well at all.. I know this sounds very simple to do but if it it installed wrong it will not run fast.. The injectors are fired off the wheel in the distributor . Just a thought after I sold a car that I had a TON of money in and it would not run very fast and I installed the distributor incorrectly.. haha
hutt1 is offline   Reply With Quote
Old 05-21-2015, 12:28 PM   #492
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Pretty sure the distributor is in correctly, but I'll eyeball it again.
Alternator due back today and I'm going to stop and pick up two new O2 sensors just for good measure. The recorder for the PMS should arrive tm...I will then be able to log/review runs to do some intelligent tuning.
If all goes as planned I will forgo the TNT Friday at Bowling Green for the SportsNationals and haul the Mustang back to Buffalo Valley Friday evening for some tuning. I'll just roll into BG Saturday morning with the Camaro.
Rich Taylor
I/SA - 321
Old 05-22-2015, 01:08 AM   #493
HandOverFist
It was there all the time...just needed a better meter to read it.
I'm going to say I have been chasing a non-existent problem all week. According to Anderson that line in the screen is for the boost tables only...not sure it would ever read the true barometric pressure. Oh well, with the TPS at 100% and the new O2 sensors I'm ready to try it again.
Rich Taylor
I/SA - 321
Old 05-22-2015, 12:01 PM   #494
SSGT Mustang
Liked 204 Times in 54 Posts
Good news. Real nice meter. Keep us posted. Get the car to hook just right, and then work the timing a bit. Have fun.
SSGT Mustang is offline   Reply With Quote
Old 05-23-2015, 09:44 PM   #495
hutt1
I know your at bg but did u get to test the mustang? I saw your q2 pass and it looked pretty nice ..
Old 05-23-2015, 09:54 PM   #496
HandOverFist
Yes, took it to Buffalo Valley Friday nite. Got it running decent, but according to the recorder timing is maxing out at 30 degrees. Have not figured out yet how to bump it up with the controller.
I'll be back at BG in the morning...will not make the same mistake I did first round of the NitroPlate race.
Rich Taylor
I/SA - 321
Old 05-26-2015, 08:31 PM   #497
Tony Corley
Liked 61 Times in 25 Posts
How did it do?
Tony Corley is offline   Reply With Quote
Old 05-26-2015, 08:38 PM   #498
HandOverFist
Only managed a 8.35 Tony with the timing limited to 30 degrees and the starting line slip. I'll have to take it back to BG once I figure out how I somehow locked the timing out.
Rich Taylor
I/SA - 321
Old 05-29-2015, 04:08 PM   #499
HandOverFist
Believe I have the timing issue resolved...will have to record a pass to confirm. Added 120 pounds ballast today so it will be legal weight the next race. Found out this afternoon the replacement one-wire alternator has quit charging again. The only thing I can think of off hand is that small crank pulley must be spinning it too fast. When it was working it showed around 14.1 volts at idle.
Rich Taylor
I/SA - 321
Old 05-29-2015, 07:50 PM   #500
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Rich,
What brand alternator do you have? My East Coast Electric has a small pulley and a 4.5" pulley on the crank. It see's over 7000 engine RPM for the last 7 seasons on every pass without issue. The alternator should be self regulating regardless of RPM. What gauge of wire did you use from the alt to the battery?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
