Old 05-25-2015, 10:54 PM   #321
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Update E-F/SA Bird Build...
I won't be doing anything until the end of the season most likely. Come next spring I hope to have something befitting the car...plan is in motion.
Rich Taylor
I/SA - 321
Old 05-26-2015, 08:30 PM   #322
brent flynn
brent flynn's Avatar
I really hate to tear into my car...but,that tenth that i shoulda gained is driving me nuts! hehe
Old 05-27-2015, 11:34 AM   #323
Robert Simpson
Liked 20 Times in 12 Posts
Originally Posted by brent flynn View Post
Glad to hear its running well... we'd be a killer heads up! hehe
Im not sure, but i think my intake valve angle and bowl hog may be hurting my deal... we never flowed anything to see if it helped or hurt... cam seems to have hurt my engine a tad... it didnt do anything for powerband, but, it didnt seem to hurt torque... Im thinking of changing cam, back to my old one, but might make more sense to check heads first... Either way, 266/272 is alot of cam... My deal likes way less... It shows no more MPH, at 1/8 or 1/4 mile, so it has gained me no HP...I believe its slowed me near a tenth, but i picked some of that back up, in weight loss, and less HP drag, with the 350 trans...
Brent, did you take a cranking compression test? Can you advance your cam any more? If you can take a test before and after you move the cam. You are blessed with torque so I guess go with it... I really like the build you have done it looks great and is running really well.
Robert Simpson is offline   Reply With Quote
Old 05-27-2015, 09:14 PM   #324
brent flynn
no, Robert, i didnt.... I'm at .080 piston/valve clearance now... Im in at 104ICL... Im gonna go back to the small cam, and when i feel like it, im gonna check flow on current heads, vs some other castings...
Old 05-28-2015, 12:04 AM   #325
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Hi Brent, is the .080" V to P clearance on the intake or exhaust, it's rare that they both come even close to the same number.
Old 05-28-2015, 09:26 PM   #326
jcw31
Liked 6 Times in 6 Posts
Hi Brent After reading this, I agree with you trying the smaller cam is worth it. I dont think that a lot of stocker cams are super big in duration or as tight a lobe separation as one would think. Also there are alot of gains in tuning such as plug heatrange ,type of plug (iridium,ground strap,projection) which Billy Nees pointed out .If you think about it there's probably 20 different things to try before major surgery. Keep trying, you will get where you want to be.
Joe
jcw31 is offline   Reply With Quote
Old 05-28-2015, 10:31 PM   #327
brent flynn
Intake was .080.. exhaust showed over .100 i stopped checking after that...hehe
Old 05-28-2015, 10:33 PM   #328
brent flynn
Joe
IF it rains out Saturday, im pretty sure im gonna start ripping down , to put smaller cam back in... No matter what i do, otherwise, the engine liked the other cam better... i dont know if the heads are a factor, or what, but, i show absolutely no gain in HP, actually, i probably lost 10-15 and gained it back with trans swap and 30# weight loss...
Old 06-25-2015, 08:17 PM   #329
jcw31
Brent, have you had the car out again?
Old 06-28-2015, 09:13 PM   #330
brent flynn
Well, its rained out the last 3 weekends... last weekend, i decided to change back to the old cam(smaller), and car is ready to test Wednesday and race on July 4th... hoping for some good #'s! Car sounds better than i remembered...so we shall see...
