Old 06-29-2015, 11:59 PM   #1
Default Re: Dime Rocket- DNQ
Solid upper torque arm and lower cradle bushings
ID:	29416   Click image for larger version
Old 07-01-2015, 09:09 AM   #2
GTOMayhem
Liked 22 Times in 14 Posts
Thanks for more pictures Mark. I definitely have to purge my brain of street vs strip cars. I knew the torque arm bushings needed to be firmer, but never really thought about solid. Did you do anything to the lower motor mount and transmission mount? Looking forward to anything you can share. How light were you able to get it before you started adding weight back?
Rick Thomason
GTOMayhem
GTOMayhem is online now   Reply With Quote
Old 07-01-2015, 10:41 AM   #3
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Can I borrow your car for Indy?
Bob Don 128 SS
Bob Don is online now   Reply With Quote
Old 07-01-2015, 01:09 PM   #4
Rick Thomason
GTOMayhem
Rick, the main trans mount had to be fabricated with a combination of the OEM trans mount and original rubber part, which sits on an aluminum tab that's part of the engine cradle.
The OEM (r) front engine mount remains intact but we added two solid ones to the trans case .One in the left front behind the starter, and one where the right axle exits the trans.
The transmission will sit firmly in place while the engine is out of it.
About 2930 with no ballast.
Bob, I'd love to see that , but you'd have to get in line...
Old 07-11-2015, 04:20 PM   #5
Update here:
We got all the permanent weight for DF/S mounted up front and added a small weight box where we could easily fine tune the scale weight. Have to say , it didn't help much with the traction though. We're hoping it will be somewhat better at a national event prepared track, in the daytime
We haven't really done anything with the suspension yet.
I'm going to have to research the availability of an adjustable front strut or at least a stiffer one. Then maybe fool with the camber and toe in.
Still need to do something about the steering rack. We need to replace it with a manual one or maybe one tooth less on the pinion?
Anyway..Last night at Wild Horse:
90 to 100 degrees
4000 to 4600 da
28.5 baro
All runs between 1.09 and 1.14 under NHRA index for sea level tracks.
ID:	29581   Click image for larger version
Old 07-11-2015, 04:50 PM   #6
Billy Nees
Ya know Buddy, just when I start thinkin that you're getting soft or thinkin about givin up, ya come up with sumpthin innovative and different! I'm impressed!
AND it's affordable!
Billy Nees 1188 STK, SS
Old 07-11-2015, 05:46 PM   #7
Somebody said a while back that some cars just have to be built.
Even if only a few of us care.
Thanks, bro
Old 07-12-2015, 08:21 AM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Is there any other kind?
Old 07-12-2015, 12:34 PM   #9
SSDiv6
Update here:
90 to 100 degrees
4000 to 4600 da
28.5 baro
Mark, BMR suspensions has suspension pieces for your car. Also, there is a company that sells a traction bar for controlling the front A-arms during acceleration and there are also aftermarket mount for the engine and transmission that replaces the gel filled OEM mounts. After looking at the BMR pieces, you might be able to replicate them.
http://zzperformance.com/3800/suspen...ion-mount.html
http://zzperformance.com/3800/suspen...dog-bones.html
http://zzperformance.com/3800/suspen...ral-links.html
http://intense-racing.com/Merchant2/...y_Code=3800_BS
http://www.bmrsuspension.com/?page=p...3&maincatid=53
You can use the KYB AGR adjustable front struts.
http://www.ebay.com/itm/KYB-734058-F...618897&vxp=mtr
Old 07-12-2015, 01:37 PM   #10
Thanks, Joe
I think we could use the struts.
The rest has already been addressed or lists only the 3800 (Buick) engine.
I'm thinking we need to change the top of strut swivel to something of a spherical bushing nature. That in itself ought to help with the hard steering problem.
Do you think we could find something close, or time to fab something there too?
You know anything about the rack/pinion tooth count deal?
