Liked 35 Times in 11 Posts
As some of you may know I bought Ken Robinson's 88 turbocoupe stocker,I made it out to the track once before it closed for the season, it only went 14.80 @just a weak 88 mph! not very impressive but it has tons of potential,im changing a bunch of stuff over the winter and hopfully i can get it to run the R/S index of 13.95, so far I took the head off and had a stocker valve job done along with some new valve springs and retainers.,a new 3" down pipe and a header, I think it will a fun project for now im going try and run the index on the cheap and see what happens.
Liked 129 Times in 59 Posts
Good Luck with the new ride, Fred! Looks like you're going to be having some fun this year!!
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 397 Times in 156 Posts
Looks like fun, love the pic of the driveway and all the fords! LOL!
Fred,
Running under the index shouldn't be much of a problem for a turbo car. What are you using for a transmission?
T5 for now mark,but I had my eye on some of that 2.3 C4 stuff on your page !
#6 | |
I started with a T 5 out of T/C (3.95 low), in the Mustang. First problem was the syncros wouldn't let me power shift it over 6 grand. So I bought a Harbor Freight Dremel copy and slick shifted 2,3,4. Then took 5th gear completely out of it. I had to make a shifter blocking plate so I couldn't go from 2nd to 5th. The 3rd gear slot was a little narrow and hard to find while pushing away from you. After that, I never had a shifting problem for the two years that I ran the stick shift.
Mark the plan is to run the T5 til it breaks,thats when I buy an automatic setup,for now I just want to get it flowing a little better with the header and downpipe,it had a stock exhaust manifold and stock 2.5 downpipe,it also had some ignition issues when I got it where you could not turn up the boost over 12 psi, after a good tune up it cleared that up but it still lays down over 3500 rpm that's why I pulled the head and checked the springs and valve job, (springs were shot) 80lbs on the seat.
A little update on the tbird,I ran it a couple of weeks ago it went a best of 13.73 @95.55 still not right but its getting there.
https://www.facebook.com/fred.goodwi...type=2&theater |
Liked 7,783 Times in 1,743 Posts
Fred, good to see you getting the T-bird out!
Congratulations on your progress!
Keep thrashing on it and you'll be rewarded. Have fun and good luck too. |
