Old 09-13-2015, 09:41 PM   #11
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Death Of A Block
The block will become a cam break in tool. Turn the mains upside down, oil pump, drive gear, oil pan, heads, rockers, front cover with hole, and 1/2'' drill. I only do four cylinders at a time in a skip one order. 1, 4, 6, 7 or 8, 3, 5, 2.
Paul the block split between 4 and 6 at its thinnest part in line with the crankshaft centerline , the block had 8 sleeves in it
I wonder if it had some core shift issues or maybe just the stress from the sleeves. I normally use .002" interference with thin wall sleeves. The cam break in tool idea sounds good, have you done it this way before, I'm wondering if the cam will miss the oil that is thrown off the rod journals. I'm guessing with only 4 cylinders and light springs the drill have it pretty easy. Will you run it continuous or in short sessions.
Old 09-14-2015, 07:42 AM   #12
Liked 10,769 Times in 2,238 Posts
No crankshaft, all lifters are used, no valley pan, valve covers, I use the Comp additive, good oil in the pan, oil filter, stock springs, ceramic lifters, run time is about 20 to 30 min per four cylinders. Everything is mounted on a roll around engine cradle.
Old 09-14-2015, 09:21 AM   #13
Ron Middleton
Liked 12 Times in 4 Posts
Would love to see a couple of photos of this setup Larry. Sounds like a good idea.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
