Old 10-05-2015, 01:24 PM   #1
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Peanut Port Drag Test
Not a bad start,, could hear the stumble, but sounded good on the gear changes. Maybe a squirter change is needed,, you've been around enough of them to figure out what it wants. Pretty good numbers, considering the moderate cam you're using. Seems like a little vibration going on there in the top end, but overall a good outing. I agree,, more laps will bring better numbers. Thanks for sharing.
We're in the process of sorting out my son's '69 Nova,,, like you, good numbers so far, with more to come. You can check it out on youtube also. Type in: Aaron Durham Nova. Take care.
Danny Durham
Old 10-06-2015, 07:14 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: Peanut Port Drag Test
HP the car sounds and runs good. I have a couple questions about the cylinder heads.
What drew you to this style head? Vs a 049 style oval port?
Did you have to replace the exhaust seats? Hardened?
How much do you think you increased the volume when finished?
Did you have to fill the intake manifold to match, or was it close?
Do you think there would be any problem using this style head or the 90's version on a tow truck 496CI combination, and if so what cam and intake?
Last is that Scott Welborns old car?
Thank you and keep up the great work it really looks good.
Robert Simpson is offline   Reply With Quote
Old 10-06-2015, 09:21 AM   #3
HP HUNTER
Liked 373 Times in 129 Posts
Thanks for your interest.
1.What drew you to this style head?
I was running out of 781 and 049 castings in my engine building buisiness.
2.Did you have to replace the exhaust seats?
No, on muscle car builds I do not replace seats, but I'am a fanatic on round strait properly sized and finished valve guides which lets me make a very concentric seat with a extremely nice contact patch that transfers heat good due to the valve setting down on the seat perfect every time. Tow applications get a 1.750 CHE exhaust seat.
3.How much do you think you increased the volume when finished?
I don't know I didn't check it, I machined, built, dyno tested, installed it in 7 days.
4. Did you have to fill the intake manifold to match, or was it close?
No, I smoothed the plenum divider, the intake is not the cork.
5. I have built tow engines close to this, this engine would be good in my dualie, except the 9.3 comp would worry me along with the 1.880 exhaust valve size. I will put a link up to my 489 tow build along with a picture.
http://speedtalk.com/forum/viewtopic...447590#p447590
6. Last is that Scott Welborns old car?
Yes, I bought it from Dale Hulquist the BSer, when it arrived I realized it would need a total rebuild from front to back, and thats what it got.
Old 10-08-2015, 07:26 AM   #4
Robert Simpson
HP thank you for the info. Speaking of the tow truck combination. Why would you use a different exhaust valve? Heat? Then what C.R. would you use for a truck? Lastly, do you know what other engines/trucks come with peanut style heads? 1990's? 80's etc? Sorry if I struck a cord about your car, it does look and run good.
Robert
Old 10-08-2015, 09:04 AM   #5
HP HUNTER
Robert
In the link above the comp was 8.25 and the reason for that is to protect myself and the customer, he was pulling 20,000 plus pounds. I wouldn't want a 1.900 seat put in a production BBC head I was towing with because I wouldn't want to get that thin in that area, thats why I use a 1.720 valve. If you would read the link, you will see power was 550 HP with 600 TQ. No need to apologize about the car, its no problem for me.
Old 10-20-2015, 08:40 AM   #6
Robert Simpson
HP thank you for the info. I did read the article in the link. But, I did see where there was possiably more info to the story (picts and all) that I did not have access to until I register. I have just not done that yet. But, thank you for the info. Again your car looks and runs really good. Have a good one.
Robert
Old 10-28-2015, 09:26 PM   #7
HP HUNTER
Update: I ran the car at Bandimere in some 8800 DA conditions, 24.24 baro. I was able to figure out the off idle stumble and was able to run a 1.47 60, 6.95 660, 11.05 1320 on Sunday, If I could have figured out the carb Saturday when the baro was a whole 24.38 and had my 29.5s on there surely I would have seen some 10s.
Old 02-22-2018, 04:28 PM   #8
Jim Hanig
Liked 99 Times in 49 Posts
Why would you buy it ?
Old 02-23-2018, 12:00 AM   #9
HP HUNTER
After a front to back rebuild I've won several races with it, run incredibly fast with a production block/head combination, I love this car.......that's why
Name:	Vortecpro Chevelle.jpg
Old 02-23-2018, 10:20 AM   #10
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
👍 x2
