#1 | |
Liked 373 Times in 129 Posts
I was running out of 781 and 049 castings in my engine building buisiness. 2.Did you have to replace the exhaust seats? No, on muscle car builds I do not replace seats, but I'am a fanatic on round strait properly sized and finished valve guides which lets me make a very concentric seat with a extremely nice contact patch that transfers heat good due to the valve setting down on the seat perfect every time. Tow applications get a 1.750 CHE exhaust seat. 3.How much do you think you increased the volume when finished? I don't know I didn't check it, I machined, built, dyno tested, installed it in 7 days. 4. Did you have to fill the intake manifold to match, or was it close? No, I smoothed the plenum divider, the intake is not the cork. 5. I have built tow engines close to this, this engine would be good in my dualie, except the 9.3 comp would worry me along with the 1.880 exhaust valve size. I will put a link up to my 489 tow build along with a picture. http://speedtalk.com/forum/viewtopic...447590#p447590 6. Last is that Scott Welborns old car? Yes, I bought it from Dale Hulquist the BSer, when it arrived I realized it would need a total rebuild from front to back, and thats what it got. Last edited by HP HUNTER; 10-06-2015 at 09:35 AM. |
Liked 20 Times in 12 Posts
HP thank you for the info. Speaking of the tow truck combination. Why would you use a different exhaust valve? Heat? Then what C.R. would you use for a truck? Lastly, do you know what other engines/trucks come with peanut style heads? 1990's? 80's etc? Sorry if I struck a cord about your car, it does look and run good.
Robert |
#3 | |
http://speedtalk.com/forum/viewtopic...447590#p447590 Last edited by HP HUNTER; 10-08-2015 at 09:07 AM. |
HP thank you for the info. I did read the article in the link. But, I did see where there was possiably more info to the story (picts and all) that I did not have access to until I register. I have just not done that yet. But, thank you for the info. Again your car looks and runs really good. Have a good one.
Robert |
Update: I ran the car at Bandimere in some 8800 DA conditions, 24.24 baro. I was able to figure out the off idle stumble and was able to run a 1.47 60, 6.95 660, 11.05 1320 on Sunday, If I could have figured out the carb Saturday when the baro was a whole 24.38 and had my 29.5s on there surely I would have seen some 10s.
Liked 6 Times in 6 Posts
HP how would it have compared if you ran the next bigger cam 238/248 114?
#8 | |
Liked 99 Times in 49 Posts
After a front to back rebuild I've won several races with it, run incredibly fast with a production block/head combination, I love this car.......that's why
Liked 783 Times in 195 Posts
👍 x2
