Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 10-14-2015, 01:04 AM   #1
John Kissel
Liked 230 Times in 94 Posts
Default Pressure washer soap
I have a metal covered pole barn garage by C.B. Structures that I am trying to clean and all of the stuff I have bought from the "big box stores" do not suds up and leave a clean surface. I have washed it several times the same day, and when I am done, you can still find dirt on the siding when you rub your hand on it. The building is 10 years old and one of the best things I have ever bought and also need something like a water soluable wax to put some color back on the roof due to the sun baking the roof. Thanks in advance, John Kissel K242
John Kissel is offline   Reply With Quote
Old 10-26-2015, 09:58 PM   #2
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Default Re: Pressure washer soap
I use a product called JoMax on my house and garage. Box stores have it. Never used it on metal tho. Works great on the house(painted) and the garage (vinyl siding). Don't need a pressure washer.
Mike Moller
NHRA 203 Q-R-T/SA
Old 11-29-2015, 10:36 PM   #3
House of Darts
Liked 20 Times in 15 Posts
That's the best you'll get with a power washer. Anything better that that requires manual brushing.
House of Darts is offline   Reply With Quote
Old 12-06-2015, 10:16 AM   #4
Dick Butler
Liked 32 Times in 19 Posts
Found no better results pressure washing Motor Home. It has to be brushed.
Old 02-06-2017, 04:51 PM   #5
Coleydog
Liked 53 Times in 38 Posts
Mix some Purple Stuff in the mix, I used it on old paint on cars, takes the crusty top off, spray wax after in the pressure washer. Try in a small spot first for strength of mix.
Old 02-06-2017, 08:33 PM   #6
MAURICE BLENDHEIM
Liked 287 Times in 88 Posts
John…Back in the late 70's I had a part-time job pressure washing Commercial Fish Boats while on dry dock, we used Tide laundry detergent and a jug of bleach. Mixed together and dilute with water for desired concentricity. Pretty much removes everything, also works good for removing oxidation off old cars. Try it, you'll like it. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
