Old 11-03-2015, 11:44 PM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Peanut Port Drag Test
Originally Posted by jcw31 View Post
HP how would it have compared if you ran the next bigger cam 238/248 114?
I had 9.3 compression, I think it would be slower, but I don't know.
Old 04-03-2016, 12:03 PM   #2
HP HUNTER
Update,
I had the peanut port out this weekend at Pueblo, 25.10 baro, 7000 DA, made suspension adjustments, along with 29.5 Hoosiers and ran the following
60 1.42
330 4.35
660 6.82
660 98.8
1320 10.86
1320 120.4
Old 08-03-2016, 06:22 PM   #3
pfordamx
Liked 7 Times in 5 Posts
I'm really impressed your horsepower and weight make that seem like a 11.20 combo not a high to mid 10 second combo. someone knows how to build a efficient car that works. nice job
pfordamx is offline   Reply With Quote
Old 08-04-2016, 08:39 AM   #4
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Great runs. Pretty impressive.
Have you ever done any work with the 366 truck motor? I know it is a high deck block, but we noticed it has smaller Main Journal size 2.50 like a 409 motor.
Does anybody know if this motor listed in the NHRA guide? Probaly not since it only came in dump truck/buses.
Will
Old 08-04-2016, 03:01 PM   #5
jcw31
Liked 6 Times in 6 Posts
HP is this the same engine combo with no changes as last year? Also if you had to make changes would you use a cam with a tighter lobe sep. ? What icl is the present one in at?What if you wanted to make more upper hp but not kill the bottom to increase the back half.Seems like you are running as fast as some alum. head roller cam more comp. engines.How about some thoughts on this.Most builders would cringe at a 114 ls.
jcw31 is offline   Reply With Quote
Old 08-05-2016, 08:25 AM   #6
HP HUNTER
It is the same combination as last year, just dialed in now, low 10s. The cam was used to keep the engine as close to what I sell as possible, the cam has great vacuum and works great in a street driver. There is better cam choices when it comes to the track for sure. I feel I've maxed the combo out and its time to move on to my 620 HP oval port combo, I think you will like that cam, 108 LC, peaks @ 6600 RPM, the peanut port peaked @ 5900, although it ran through @ 6900 RPM. Stay tuned....
ID:	35385   Click image for larger version
Name:	my peanut port 467.jpg
Old 08-05-2016, 09:12 AM   #7
jcw31
It ran 10.80s at 7000 da is this corrected or what would you expect at 2000 da
Old 08-05-2016, 09:50 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Will
366 has same main journal size as other BBC don't know of many ever doing anything much with them,had a friend ran them years ago in Super stock 4wd pulling,they had 366'' limit,they made the rules don't guess they thought of anyone building 366'' BBC, he dominated it.
About all we have ever done besides build them back stock, is use the cranks,in 396,427's and use the rods for stock rebuilds.
366 wouldn't be good for any kind of budget build,by the time you had custom pistons made that would be more than the difference in $ of 454/427 block,could build bigger for same or less money.
HP,I like your build.
Mike Taylor 3601
Old 08-09-2016, 09:46 PM   #9
HP HUNTER
Mike Taylor 3601
Thanks for the nice comment!
