#31 | |
Liked 118 Times in 41 Posts
#32 |
Liked 19 Times in 12 Posts
It's on the earlier models. Can't say for sure when they stopped using them. A plasma cutter would do well to lighten up the steel bumper but then you are giving up some strength in the event of a mis-hap. I saw where a guy water jetted the crap out of one until it was basically a skeleton.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#33 | |
Liked 7,862 Times in 1,750 Posts
#34 | |
Liked 275 Times in 76 Posts
FWIW, My stock steel one weighed 31lbs, the aluminum one weighs 13lbs 15oz, everything that was pulled from my car I have records of what the item weighed and what the new item is as well. If you remove and or replace the heavy items you could then move your car down to the lightest class and still add weight to meet minimum. But you add weight where it helps make the car work. Billy makes a very valid point, careful on what you cut on, it could get you into trouble in tech. Sean
#35 |
Thanks much for the input. As I said before. I want to do it right the first time. I had the day off yesterday so i made some headway.Is it possible the door bars are spot welded to the door skin? It looks like they are spot welded in about 10 places top and bottom of the bar.
#36 |
Two pic's of what I got done.
#37 |
Liked 204 Times in 54 Posts
Time for the heat gun and scraper to get rid of all the rubberized coating on the back floor and tunnel.
#38 |
Oh yeah what am I thinking?!?! Forgetting its a Stocker. My mistake- apologies for any confusion. Thanks.
#39 |
We have been doing this all spring and summer and we did get our GT Turbo (which was an 86 SVO car so its an original heavy car 2975 pound car when we started) to 2520 pounds with driver with the factory seats still so u can make the weight it just takes a little time..
Scott |
#40 |
I had a little extra time today so I made a little headway. Pulled out the heater and all the related pieces, radio, speakers, and all under dash. insulation.
I have 2 questions. Maybe stupid but I must ask. The fresh air intake vents. Is it ok just to block them off with sheet metal? The car has a inside hood release. Is it ok to do away with it and make the hood release from the front grill area? My cable is broken and I can fab a handle release that will work fine. |
