Old 01-09-2016, 10:05 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Team Woodfin's Bantam Roadster Build
so you can see part of the vision
ID:	32114   Click image for larger version
ID:	32115   Click image for larger version
Larry Woodfin 471W
Old 01-16-2016, 08:47 PM   #2
Dragsinger
I like beautiful and shinny parts. Check this outstanding work by Dan Olson oil pans.
ID:	32221   Click image for larger version
ID:	32222   Click image for larger version
Larry Woodfin 471W
Old 01-17-2016, 08:35 PM   #3
Dragsinger
A good work day - planning day for the Roadster
ID:	32238   Click image for larger version
ID:	32239   Click image for larger version
ID:	32241   Click image for larger version
ID:	32242   Click image for larger version
Larry Woodfin 471W
Old 01-26-2016, 08:52 PM   #4
Dragsinger
At Woodfin Automotive we work on EFI equipped cars and truck most every day. Yet, we do not race those cars ! Nor do we engineer the systems, we simply repair them.
Our roadster is not only a new exercise in drag racing with EFI it also requires some home spun engineering.
In keeping with the basic theme of hot rodding if you are not modifying or customizing every part on the package you are being remiss.
The engine is a Brodix aluminum block with raised cam and raised deck. EVERYTHING that bolts on the block requires some tweaking.
Here I am spotting the magnet bolt that will screw into the cam gear. The magnet is set at 195 degrees before TDC #1 firing. It identifies the #1 cylinder position for the ECM and begins the injector firing sequence.
ID:	32280   Click image for larger version
Larry Woodfin 471W
Old 01-28-2016, 09:13 PM   #5
Dragsinger
the cam sync sensor tucked behind the water pump
bolt with magnet in head for sensor signal
ID:	32286   Click image for larger version
ID:	32287   Click image for larger version
Larry Woodfin 471W
Old 02-01-2016, 08:48 PM   #6
Dragsinger
Q - What is required if the fenders need to be wider? If you want the tire tread under the fender?
A - Modification! Simply cut off them off, splice the width, reinstall. No hill for a hot rodder More specifically, our team member body man extraordinaire,Joel.
ID:	32291   Click image for larger version
Larry Woodfin 471W
Old 02-01-2016, 08:50 PM   #7
Dragsinger
Q - How many ignition coils does an Holley Dominator EFI system need?
A - All of them!
ID:	32293   Click image for larger version
Larry Woodfin 471W
